Brake Kits
Does anyone know any good after market brake kits for 94-97 Accord....ive been having trouble trying to search for a brake kit....including aftermarket calipers....drilled and slotted rotors....etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Don't get drilled/slotted rotors. They are more prone to crack and they have less stopping power then blanks. They are simply for looks.</TD></TR></TABLE>
cross drilled/slotted rotors are for heat disipitation, let gasses between pad and rotor to escape, weight savings, and in some cases to 'clean' the pad. but unless your tracking your car its not neccessary
4-PISTON CALIPERS!!! This big brake kit will greatly reduce stopping distances and really improve the performance look of your Accord. The kit is made up of top of the line race inspired components. Stock offset wheels will not work with this kit. The calipers stick out further (because of pistons on the outside) and will require a wheel with less offset than stock or the use of wheel spacers.
Kit includes:
2-piece cross-drilled & slotted 12.2" rotors
Wilwood 4 piston calipers
Wilwood performance brake pads
Front stainless steel braided brake hoses
Caliper brackets
Hub to rotor adapters
All necessary hardware and instructions
6-PISTON CALIPERS!!! This big brake kit will greatly reduce stopping distances and really improve the performance look of your Accord. The kit is made up of top of the line race inspired components. Stock offset wheels will not work with this kit. The calipers stick out further (because of pistons on the outside) and will require a wheel with less offset than stock or the use of wheel spacers.
Kit includes:
Wilwood 6 piston calipers
Caliper brackets
From TAS atuto
Modified by H22edAccord at 1:30 AM 9/4/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23Accord »</TD></TR><TR><TD CLASS="quote">You can also do the Acura Legend brake swap. An inexpensive alternative.</TD></TR></TABLE>
Only problem is that they are rare to find as a GS legend.
As you increase your Accord's performance, the stock brakes quickly become inadequate. You can now replace your 10" factory rotors and improve braking while still being able to use the 15" factory wheels. The TASPRO kit includes two 11" cross-drilled rotors, two front caliper brackets, Carbomet brake pads and the proper brake pad clips. For use with 15" or larger wheels. For even more stopping power, check out the Braided Steel Brake Lines.
$250 plus shipping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98AV6205HP »</TD></TR><TR><TD CLASS="quote">cant go wrong with brembo, but they are pretty expensive. But u get what u pay for.
i dont think brembo makes a brake kit that replaces both the caliper and rotor for the accord
</TD></TR></TABLE>i dont think brembo makes a brake kit that replaces both the caliper and rotor for the accord
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 »</TD></TR><TR><TD CLASS="quote">i dont think brembo makes a brake kit that replaces both the caliper and rotor for the accord</TD></TR></TABLE>
They do, its in the Gran Turismo lineup and it costs a fortune. Ive seen the Brembo kit on a 5th gen Wagon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gianinline »</TD></TR><TR><TD CLASS="quote">
Only problem is that they are rare to find as a GS legend.</TD></TR></TABLE>
Because you can't go to your local auto parts store and ask for calipers for a GS Legend, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj »</TD></TR><TR><TD CLASS="quote">
They do, its in the Gran Turismo lineup and it costs a fortune. Ive seen the Brembo kit on a 5th gen Wagon.</TD></TR></TABLE>
LOL that's pretty funny. I forgot all about Grand Turismo!
bosco500
10
Feb 7, 2005 12:18 PM
