Idle and firing problem please help!!!!
Old Aug 31, 2006 | 08:04 AM
accordh22sleeper's Avatar
Default Idle and firing problem please help!!!!
i recently swapped an h22 into my 94 accord,,, and for the past two weeks i have been having the same problem,,, cylinder one is not firing,, i checked the spark plugs and the spark plugs wires,, i changed the coil,, even swapped distributor,, and still having the same problem,,, my mechanic says he has never seen that problem,, because he has checked everything,, timingbelt,, sensors,, wiring,, almost everything,, i have gotten a few people to take a look at it and they cant come up with anything the cylinder has great compression (223psi),, i am also having trouble with the idle,, in order for the car to stay on i had to disconnect a vaccum line,, i have checked almost everything on that also,,,so if theres anyone that might know anything else i should check please let me know you help is well appreciated,, thanksssss
l_thenth
Aug 8, 2007 01:05 AM
CARflyGUY
May 30, 2007 07:20 AM
Gee3
Oct 31, 2004 09:05 PM
NightHawk
16
Apr 16, 2003 05:52 PM
Accord88
Feb 23, 2003 05:53 AM
