Suspension & Brakes Theory, alignment, spring rates....
Wheel Vibration at 80-90 mph...Second Opinions wanted.
Old Aug 31, 2006 | 07:07 AM
EnjoyTheRideDC2's Avatar
Default Wheel Vibration at 80-90 mph...Second Opinions wanted.
I recently swapped out the UCA's on my 97 Integra ,from OEM to Skunk2's. I got the car aligned a couple weeks after. Everything felt fine, until I started driving in the 80+mph range. Once you hit 80, you'll begin to feel a mild vibration. Then at 90 and up, the vibration becomes violent, causing the wheels to hop or something. You'll hear the tires as if they were looking for traction.
Off hand, my guess is the tires are unbalanced. ANyone have similar experiences or maybe a second opinion based on my info?
Old Aug 31, 2006 | 07:28 AM
zguy95135's Avatar
Default Re: Wheel Vibration at 80-90 mph...Second Opinions wanted. (EnjoyTheRideDC2)
Yea it does sound like you wheels or tires are imbalanced, not enough to notice at low speeds but obviously enough to make it violently shake. Check you tires for some tread seperation too.
Old Aug 31, 2006 | 07:45 AM
Default Re: Wheel Vibration at 80-90 mph...Second Opinions wanted. (zguy95135)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zguy95135 &raquo;</TD></TR><TR><TD CLASS="quote">Yea it does sound like you wheels or tires are imbalanced, not enough to notice at low speeds but obviously enough to make it violently shake. Check you tires for some tread seperation too.</TD></TR></TABLE>
Would signs of tread seperation simply be areas where the tire looks like its expanding or would there be something distinctive about it?
lambertincorp
Dec 29, 2007 02:03 PM
EnjoyTheRideDC2
Aug 31, 2006 01:48 PM
ekhatch9
Jun 22, 2006 02:33 PM
camera obscura
Apr 9, 2003 06:38 PM
