1997 Accord EX, makes zzz noise, then abs light comes on
Old Aug 31, 2006 | 07:04 AM
josh_c27030's Avatar
Default 1997 Accord EX, makes zzz noise, then abs light comes on
Every time i crank my car up, theres this noise for about one minute, then the abs light comes on and stays on? is the abs bad? does it need to be replaced? how do i fix this problem? thanks
Old Aug 31, 2006 | 01:40 PM
philadd's Avatar
Default Re: 1997 Accord EX, makes zzz noise, then abs light comes on (josh_c27030)
You need to get the code pulled for the ABS unit.
Old Aug 31, 2006 | 02:56 PM
hondadude's Avatar
the code will probably be "pump overrun" the first thing to do is check for leakage around the ABS unit. Next thing to do is bleed the pump unit. I've seen lots of those units that have a bad check valve and will not build pressure. Nobody offers the Check valve as a part, you have to buy the whole unit.
coolswimmerjon
Jan 31, 2016 01:05 PM
russianswty
Feb 11, 2007 07:31 PM
kbxer22
Honda Civic (2001 - 2005)
Dec 24, 2006 07:29 PM
iLUVmyACCORD
Jan 6, 2005 04:49 PM
accordhybrid
Jun 2, 2003 02:37 PM
