97 Accord - AC Condensation Interior Leak
Old Aug 31, 2006 | 06:47 AM
offroad's Avatar
Default 97 Accord - AC Condensation Interior Leak
My 97 Accord SE is leaking condensation from the AC into the interior.
There is a hose that goes from the condensor shroud (looks like thats what it is anyway) through the firewall where it meets the carpet. When I pulled the hose from the shroud, there was alot of water that came out of the shroud.
The hose is clear and also I also ran some wire through the hole in the firewall and saw it drop down under the car so this appears clear as well.
The actual area the drips are coming from is a bit more towards the center of the car and closer to the firewall. At least thats where the drips are hitting the carpet anyway.
Any ideas for a fix would be greatly appreciated.
Thanks.
Old Aug 31, 2006 | 08:14 AM
offroad's Avatar
Default Re: 97 Accord - AC Condensation Interior Leak (offroad)
Forgot to check the email replies box.
Old Aug 31, 2006 | 02:46 PM
hondadude's Avatar
the Evap drain inside the case is where the crud stops up the flow. A temp fix is to blast the drain tube with compressed air and that will move the debris away from the drain for a few months. The real fix is to open the case and clean out the trash.
thequesogrande
Jun 26, 2013 09:56 PM
96AccordMD
Jun 16, 2009 10:38 AM
marrieda97accord
Jul 6, 2008 12:06 PM
Grayson
Jul 16, 2005 03:14 AM
tjohnson329
May 27, 2005 06:03 PM
