Suspension & Brakes Theory, alignment, spring rates....
Struts on coilovers
Old Aug 31, 2006 | 05:50 AM
onepoint-gsr's Avatar
Default Struts on coilovers
A friend of mine told me that you cant have aftermarket struts on coilovers. True? I dont see why you couldnt, but thats why Im asking.
Old Aug 31, 2006 | 08:18 AM
danvuquoc's Avatar
Default Re: Struts on coilovers (onepoint-gsr)
If you're talking about coilover sleeves:
You can use aftermarket shocks. It's better that way, sleeves are just height adjustable springs really.
If you're talking about full coilovers:
Most of the time you can't use aftermarket shocks. The shock bodies are made so they use their own lock rings and spring perches etc etc.
Old Aug 31, 2006 | 08:39 AM
Tyson's Avatar
do you know what a "strut" is?
do you know what a "coilover" is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint-gsr &raquo;</TD></TR><TR><TD CLASS="quote">A friend of mine told me that you cant have aftermarket struts on coilovers. </TD></TR></TABLE>
this question makes no sense if you do.
a strut is specifically a shock absorber/damper on macpherson strut cars, which all civics/integras from 88-00 did NOT have, so technically we dont have struts. only on newer, cheaper hondas. but otherwise, "strut" is used interchangably as just a "shock absorber" alone anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyson &raquo;</TD></TR><TR><TD CLASS="quote">coilover is a term thrown around a lot, kinda means different things to different ppl. you kinda have to take it in context around here.
simply a coil over design is a coil spring over the shock. as opposed to being separate, like in the rear of volkswagens. some call that a divorced spring. or even as far opposed to not even a coil spring at all like a leaf spring in a truck.
however, its commonly used as an aftermarket product. but two distinct types.
first is the adjustable spring kit, that has a threaded sleeve and different spring. the most notable brand for this is ground control. gives height and easy spring interchangability to each corner. but you can use a normal shock.
the second is a complete spring/shock system with the body of the shock is threaded, aka threaded body shock, full coilover, or often misnamed "true coilover" (see first paragraph). that would be like your KW's.</TD></TR></TABLE>
Modified by Tyson at 9:58 AM 8/31/2006
Old Sep 1, 2006 | 10:35 AM
Thanks for clearing that up for me....Yea what I ment was aftermarket shocks on adjustable coilovers with springs.
Old Sep 1, 2006 | 10:42 AM
Tyson's Avatar
you cant use regular springs with adjustable spring sleeves.
slotec
Suspension & Brakes
11
Oct 3, 2005 08:26 PM
rasinhell
Mar 16, 2005 06:48 PM
Nocturnal
Jan 17, 2004 12:35 PM
JDubya
Apr 15, 2002 02:57 PM
Typerc716
Jul 31, 2001 04:53 AM
