fuel presher a lttle high
Old Aug 31, 2006 | 05:37 AM
civicsit's Avatar
Default fuel pressure a lttle high
whats going on?
well my question is when i look at my fuel presssure it reads 60 to 61 psi. the last thing i had done to the car was just cams, valve spring , and retainers. the last time the car was tuned it was sit at about 30psi at idle now it sits at like 60psi. should i be consernd about the hight fuel presher or is something going bad.
it's a all motor set up.
if you guys can give me some ideal that would be thank full
Modified by civicsit at 5:35 AM 9/2/2006
Old Aug 31, 2006 | 10:03 AM
thesmogman's Avatar
Default Re: fuel presher a lttle high (civicsit)
I should point you to the search button. 17 post about fuel pressure.
But check your fuel pressure regulator (FPR)
Pull the vacuum line to it and see if there is gas in it. If it's clean then your problem is the regulator itself. Unless you have an adjustable then turn it down.
Old Aug 31, 2006 | 07:17 PM
egsleepercivic's Avatar
possible pinched fuel return line
gl
Old Aug 31, 2006 | 08:09 PM
TransformedBG's Avatar
Default Re: (egsleepercivic)
You have a FPR?
Old Sep 2, 2006 | 04:24 AM
civicsit's Avatar
i do have an aem fpr on there now and all return lines are fine. i may try to put the stock fpr on there to see what happends.
Old Sep 2, 2006 | 07:08 AM
have you tried reajusting the fpr?
Old Sep 2, 2006 | 07:34 AM
civicsit's Avatar
Default Re: fuel pressure a lttle high (civicsit)
i have not yet tryed to reajust it. but i did not thing it was right that it just went from 30 to 60. i have a new fuel filter, dizzi, head gasket, timming belt, water pump, radiater. so why it is now doing this it has me bogled. the o2 in the car is about 2yrs old.
Old Sep 3, 2006 | 10:47 AM
Im kind of thinking you may have bumped your ajustment or something, i would suggest reajusting it to the proper fule pressure.
Old Sep 3, 2006 | 01:30 PM
onepoint6i's Avatar
Default Re: fuel pressure a lttle high (TransformedBG)
a new filter will cause higher pressure..especially with your FPR
Old Sep 12, 2006 | 05:12 AM
civicsit's Avatar
sorry guy for not getting back quocker....
well for the update? fuel pressure gage is bad and found out i had a bad o2..lol
thanks guys for your help....
Old Sep 12, 2006 | 01:21 PM
what kind of guage
turboef90
Aug 11, 2013 12:28 PM
polishedturd
54
Jun 5, 2008 02:00 PM
hyabusa hunter
Jun 7, 2007 12:55 PM
boostaholic
Jun 30, 2002 07:25 PM
BUSAFREAK
Jul 17, 2001 08:56 PM
