How hard is it to do a conversion??
Old Aug 30, 2006 | 11:21 PM
Fezzie's Avatar
Default How hard is it to do a conversion??
ok im swapin my motor to obd1 so how hard is it to go from obd0 obd1?? what all do i have to do??
Old Aug 30, 2006 | 11:24 PM
SVOboy's Avatar
Pretty easy. You need to swap ecu and distributor. You can shell out money and buy jumper harnesses or you can spend 2 hours and do it yourself, it's just following a list and connecting wires.
Old Aug 31, 2006 | 01:13 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: How hard is it to do a conversion?? (Fezzie)
You'll need:
OBD0-1 ECU Jumper harness (Rywire.com, Ebay has a few for cheaper) $50-100
OBD0-1 Distributor harness (email me if you need one, Rywire.com) $25-35
4 wire O2 and 4 wire wiring plug (I carry the harness part/new/used O2)$5-100+
OBD1 ECU, Distributor, you can use the OBD1 injectors or keep the OBD0 and retain the injector resistor box if you want to keep the cost down
Old Aug 31, 2006 | 05:40 AM
Fezzie's Avatar
Default Re: How hard is it to do a conversion?? (HondaPartsHero)
thankx i got the dizzy and the ecu and the conversion harness, 4 wire o2 sensor well im buyin all this from a friend
sir.rexington
15
Oct 20, 2010 01:48 PM
bayron
13
Feb 26, 2009 08:04 PM
mrx
Mar 12, 2005 01:06 PM
EVOCELICA
Jul 9, 2004 01:10 PM
wickedEFguy
Feb 11, 2003 03:01 PM
