spun bearing on dohc zc, couple questions
Old Aug 30, 2006 | 08:20 PM
217sportcompacts's Avatar
Default spun bearing on dohc zc, couple questions
hey guys i spun a bearing on my dohc zc motor due to lack of oil and taking it to redline, i have a few questions as i have never replaced these before.
the mains are fine, now when i took off the lower part of the rod, the bearing wasnt even attached to it, i could just spin both of them around in a circle on the crank journal, all 3 rods did that except one, i am assuming all 3 rod bearings will need to be replaced...? also does anyone know what bearings can be used in the zc i am am worng they are the d16a6 right? also i need the torque specs for the rods and crank carriage. thanks
Old Aug 30, 2006 | 09:03 PM
290allen's Avatar
Default Re: spun bearing on dohc zc, couple questions (217sportcompacts)
get a manual for the torque specs, and the d16a1 from a 1st gen integra is the same motor. so bearings will work from that.
Old Aug 31, 2006 | 01:50 AM
Hamstr323's Avatar
I hope you don't think that all you need to do is remove these rod bearings & just replace with new ones
also did you check crank for damage?
Old Aug 31, 2006 | 03:58 AM
Boosted Chemist's Avatar
Default Re: spun bearing on dohc zc, couple questions (Hamstr323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">I hope you don't think that all you need to do is remove these rod bearings & just replace with new ones
also did you check crank for damage?</TD></TR></TABLE>
if you "spun" a bearing, usually you need ot have the rods machined and the crank polished or its going to happen again
Old Aug 31, 2006 | 04:25 AM
B18CRX_JJM's Avatar
Well you might think about checking you pistons also, if your rod bearings are all fucked up! Cuz not having enouph oil in a car usually will expletive up your piston rings 1st!
luis253
Feb 12, 2015 10:11 PM
DoHcZC91si
Feb 23, 2007 08:34 AM
travis_118
Mar 24, 2002 12:03 AM
Grumpy
Sep 10, 2001 03:49 PM
