1988 prelude si automatic ecu
Old Aug 30, 2006 | 07:21 PM
6doorsentra's Avatar
Default 1988 prelude si automatic ecu
i own a 88 prelude si thats an automatic..my gears are shifting abnormaly..i want to replace the ecu..which ECU are compatible? thanks
Old Aug 30, 2006 | 08:04 PM
JasonST's Avatar
Default Re: 1988 prelude si automatic ecu (6doorsentra)
First off, if the gears aren't shifting too well, I'd have the tranny fluid replaced, we had that done to our 91 civic a few years back, when it was having shifting problems, and it's been fine ever since.
Old Aug 30, 2006 | 08:15 PM
jsut answer my question no advice is needed
thanks
Old Aug 31, 2006 | 05:20 PM
which ones is it
Old Aug 31, 2006 | 07:20 PM
l2yanE's Avatar
Default Re: (6doorsentra)
i hate to tell ya but a tranny that old, is probably more of a mechanical issue that a computer issue- change the fluid, put sum lucas atf treatment in to it works wonders- ecu would cause very odd or lack of tranny operation completely
Old Aug 31, 2006 | 07:23 PM
fast_honda's Avatar
Default Re: (l2yanE)
If it's not mechanical, it could be your TCU (transmission control unit) and I have one I could sell you for $20 from a '93 OBD1 H23A1.
Old Aug 31, 2006 | 07:51 PM
Whats so hard about understanding I dont need your advice or what you thinks... I just wanted to know which ecu is compatible.. as for fast_honda, you da man...TCU is what i'm lookin into...thanks niqqa
Vera
Nov 2, 2004 03:19 PM
