Anyone need a K20a2 to build?
I work at an Acura dealership and i recently acquired an 02 K20a2 type s motor that sucked up water, no bent rods or anything but the cylinders were washed down and i got it to run but the oil pump lost its prime and lost oil psi. The motor never seized and it ran fine, i drove it into the shop. It has 55k on it and is complete from valve cover to oilpan and has a perfect wiring harness and flywheel and clutch. It just needs an oil pump and maybe bearings to be on the safe side. It will also need a sump. I will have pics by tom. but i need to know how much to ask. All feedback is appreciated. Thx.
motor complete except starter, alternator, knock sensor. Has harness that is good. good oem clutch and flywheel, and also i have a 06 tranny w/ 3542 miles on it. PERFECT! $make offers on each. I have not torn the motor down. I drove the car in the shop w/ no knocks and perfect compression but the oil light was on. Turns over by hand fine. The oil psi problem you have to resolve.
Skank_aSS_Dara
Nov 30, 2004 02:46 PM
