Rear washer trick... To fix negative Camber
I did it to my Eclipse a while back no problems, jacked the Prelude up today and didn't see the same suspension setup. Just wanted to know if it can be done on a 4th gen.
cause a Prelude has a better setup than a crappy Eclispe. You can't do the washer mod to a Prelude, but you can do it to a Civic
theres no way to adjust camber on a 4g prelude unless you have an adjustable ball joint up there, or you made some funky *** mount in the shock tower for the upper arm that let it slide to adjust
washers, no
custom mount ^^, not easy
washers, no
kornerk12
Suspension & Brakes
14
Jun 5, 2009 09:28 AM
