90 accord probable bad fuel pump
Old Aug 30, 2006 | 04:31 PM
jimlenfert's Avatar
Default 90 accord probable bad fuel pump
looking for "shut down valve" told to get it thru the trunk but can not find it. . I am a fool. can anyone help? thanks
Old Aug 30, 2006 | 04:59 PM
Honda-Master's Avatar
Default Re: 90 accord probable bad fuel pump (jimlenfert)
no such a thing .....
Old Aug 30, 2006 | 05:14 PM
jimlenfert's Avatar
Default Re: 90 accord probable bad fuel pump (Honda-Master)
Ok great gets fire plenty of turn over power will not start what do I do next thanks
Old Aug 30, 2006 | 06:18 PM
hondadude's Avatar
check for fuel pressure at the injector rail
Old Aug 31, 2006 | 05:49 AM
jimlenfert's Avatar
Default Re: 90 accord probable bad fuel pump (hondadude)
thanks I like a smart ***"know it all" By the way this good old car is a 90 honda accord lx 4 cyc.
Old Sep 1, 2006 | 05:53 AM
jimlenfert's Avatar
do not posess fancy tools. Can not check fuel at injector rail. Tried to remove back seat and listen to fuel pump. About tore my arm out of its socket and still could not "pop out" the rear seat. Help. Who can give me plan D. thsnks
Old Sep 1, 2006 | 05:10 PM
$300lude's Avatar
if the pump is working, then you should be able to hear it while in the front seat, just roll the windows up and turn the key to on but not start and listen for a humming for a couple seconds
Old Sep 2, 2006 | 06:25 AM
Jmumblez2001's Avatar
i've been looking to buy a fuel pressure gauge and it seems they are hard to find and rather expensive if you must check for fuel pressure take it to the shop to see why it won't start. Another common issue is your electrical starter switch (just a thought)
Old Sep 2, 2006 | 11:10 PM
hotrodaccord's Avatar
If you have basic tools you can try loosening the nut at the fuel rail, does the fuel spray out, if it sprays you got pressure. that means your pump is working. if not don't always think it's the pump sometimes the main relay can go bad. that would cause the pump to not come on.
1990IntegraLS
May 22, 2019 08:36 AM
rustyhog
Sep 7, 2016 07:05 PM
caspersrevenge1
Sep 6, 2013 05:02 PM
nichole82
Mar 28, 2012 08:30 AM
CRXMATT
Mar 20, 2003 06:01 PM
