Alternate option for VSS?
Old Aug 30, 2006 | 04:20 PM
rawkus's Avatar
Default Alternate option for VSS?
Well...
I purchased a transmission with a Quaife Differential installed. Everything looks great, trans shifts fine, differential really makes a difference in low speed turns, but the VSS is not working. I looked in the hole, and notice that the VSS Gear was not pressed onto the differential. Is there another option for replicating a Vehicle speed signal without removing the transmission? I will do it if I have to but this sucks, no vtec... any help is appreciated.
Dan
Old Aug 30, 2006 | 05:35 PM
v4lu3s's Avatar
RTFM
chip your comptuer and get rid of the vss/speed check
Old Aug 30, 2006 | 06:15 PM
MadCityLude
Guest
Posts: n/a
Default Re: (v4lu3s)
I think he would still need some sort of VSS if he wants a speedometer wouldn't he? That would only alow him to get VTEC back and remove the stock speed limiter.
Old Aug 30, 2006 | 07:33 PM
rawkus's Avatar
Default Re: (MadCityLude)
Yeah, I would like a speedometer, but honestly, could do with out. The only problem is, I am planning on selling the car, and most buyers might want to know how fast they are going. I think I will just have to pull the transmission and get the gear installed. Talk about a kick in the pants.
Dan
Old Aug 30, 2006 | 11:48 PM
soundbomber's Avatar
Default Re: (rawkus)
get a stack cluster
STACK
STACK
STACK
Old Aug 31, 2006 | 10:48 AM
Chuckles99SH's Avatar
If you VSS is fucked your mileage will be off too if im not mistaken.. That will render your car unsellable in any state.
Old Aug 31, 2006 | 11:20 AM
v4lu3s's Avatar
RTFM
Default Re: (Chuckles99SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chuckles99SH &raquo;</TD></TR><TR><TD CLASS="quote">If you VSS is fucked your mileage will be off too if im not mistaken.. That will render your car unsellable in any state.</TD></TR></TABLE>
not true. in Texas at least once a car is 10 years old milage is no longer required to be recorded, the titles read exempt on the mialge part.
Old Sep 5, 2006 | 06:24 PM
Putter-GLHT's Avatar
Many states have check boxes on the title for:
Actual Mileage
Unverified Mileage
Exceedes the mechanical limits of the odometer.
You'll be cherry, come on Dan, just order the exciter ring!
turboblack2door
Jan 13, 2011 08:39 AM
213374U
May 18, 2009 02:08 AM
WuWarrior
Jan 28, 2003 11:55 AM
gatoracer
Jan 14, 2003 05:52 PM
