first of tig welding
Old Aug 30, 2006 | 02:39 PM
mynameisjustin's Avatar
Loved
Community Favorite
Default UPDATE: 9/7 first of tig welding
today was my first day doing it for my tech school training for the usaf. here was what my last weld looked like for the day. first picture is the pass and the second is the penetraion. just curious for any tips or anything. i think it looks pretty good just curious.
Modified by mynameisjustin at 6:11 PM 9/7/2006
Old Aug 31, 2006 | 11:09 AM
9295EJ-t's Avatar
stay consistent... that seems to be your biggest problem....
consistent heat.. consistent speed...
work on that.. and you will be golden!
and commenting on your pic... it isnt too bad.. you got way too hot there at the end... and it looks like there isnt enough filler metal about halfway down.. definately too hot!
dont brush it next time before you post a pic! show us what it really looks like...
Old Aug 31, 2006 | 11:25 AM
RCautoworks's Avatar
Default Re: (9295EJ-t)
Did you cut the pieces down, or are those the sizes ? Working on smaller metal is always harder, the heat has no where to go, so you will have to work the pedal more. Like 929 said, looks to be to hot, and not enough filler.
Old Aug 31, 2006 | 11:57 AM
9295EJ-t's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did you cut the pieces down, or are those the sizes ? Working on smaller metal is always harder, the heat has no where to go, so you will have to work the pedal more. Like 929 said, looks to be to hot, and not enough filler.</TD></TR></TABLE>
small pieces are a bitch.. you will have to work the pedal.. the plate is gonna heat up fast! so you are gonna have to compinsate by letting off the pedal to equal out the heat transfer.. know what i mean?
as the plate's temp rises, you need to lower the amperage of the torch.. make since?
Old Aug 31, 2006 | 01:02 PM
postman's Avatar
thats just practice beads right. at least i dont see actual 2 pieces being welded together.
Old Aug 31, 2006 | 05:08 PM
Loved
Community Favorite
Default Re: (postman)
thanks guys...welp here was day two. i laid down welds liek this all day so i just brought a couple home. those btw are not practice beads we are welding on .050 stainless steel plates we weld the mtogether right now and after that we shear it so we just keep using the 2 plates till there is nothing left. basiclly shearing the weld from the plates. here they are no cleaned. my instructor tells me just work on a steady bead otherwise my pentration is great...the silver colored weld is the bottem of one of the plates (the penetration) thanks again guys. keep'em coming. ill continue to post some welds everyday, next i believe is stainless steel t-joints. ill end up doing t-joints, butt joints, tube to tube, tube to plate with aluminum, SS, titanium
Old Aug 31, 2006 | 06:19 PM
Want2race's Avatar
what machine is that ?
looks good!
Old Sep 1, 2006 | 03:08 PM
Loved
Community Favorite
Default Re: (Want2race)
its a synchrowave 350lx, red tung. with 1/16" 347 filler rod
heres my 3rd day...
Old Sep 1, 2006 | 09:01 PM
boosted-EG6's Avatar
Default Re: (mynameisjustin)
what votage are you using? and is that stainless steel your using?
Old Sep 1, 2006 | 10:04 PM
9295EJ-t's Avatar
from the last pictures you posted, you are doing great! and im sure you know this, but you got too hot/slow near the end of the weld...
watch the puddle.. if it is starting to get a lil fat on ya, and you are moving at the same pace, let off the pedal a bit..
otherwise, just pick up your travel speed!
Old Sep 2, 2006 | 04:19 AM
Loved
Community Favorite
i have it set on 50amps...while welding my buddy told me its from 28-31amps
Old Sep 2, 2006 | 07:24 AM
vtecspeed1320's Avatar
Shooting Star
wow what an improvement from day 1...its all about your step consistency now
Old Sep 7, 2006 | 05:14 PM
Loved
Community Favorite
Default Re: (vtecspeed1320)
stainless steel t-joint...welp here was my best one
Old Sep 7, 2006 | 05:21 PM
*Boostwerks*'s Avatar
That looks REALLY good man! Keep it up
Old Sep 7, 2006 | 05:57 PM
9295EJ-t's Avatar
give it more filler...
Old Sep 7, 2006 | 06:03 PM
Loved
Community Favorite
thanks bryson...9295EJ-t yeah my instructor said the same...i have a bunch thats somewhat close to that but with more filler its just not as smooth but still after i test on this i goto stainless steel tube to tube which i cant wait for
Old Sep 7, 2006 | 09:14 PM
9295EJ-t's Avatar
it might not be as smooth.. but the weld will do its job..
are you using 1/16" wire?
a general rule of thumb with tig welding would be take 2 wires stick em side by side, and the width of the 2 wires is how big your bead should be..
if you were doing it right, the bead wouldnt be concave looking..
too much heat, and not enough filler.. keep practicing though! the welds are lookin good!
very consistant! which is a good thing!
Old Sep 8, 2006 | 05:51 AM
Loved
Community Favorite
yep 1/16". will do ill do some today and ill post them up after school
Old Sep 8, 2006 | 12:12 PM
ManBearPig4silly's Avatar
Near the end of the weld it looks like you are carrying a little contamination into the puddle with your filler rod. Make sure you keep the tip as close to the puddle as you can so you keep it in the gas coverage zone. Might want to back off on the heat a little or speed up your travel.
You might want to try just leaving the rod in the puddle at all times on stainless. It makes it so much easier.
Old Sep 8, 2006 | 01:54 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9295EJ-t &raquo;</TD></TR><TR><TD CLASS="quote">give it more filler... </TD></TR></TABLE>
yea mos def... with more seat time it will come to you.... i knocked the T's out real easy... but the horizontal is what kicked my ***.....
Good Luck.. i went to a Navy Welding school for aircraft componets
Old Sep 10, 2006 | 05:49 AM
Loved
Community Favorite
Default Re: (S@nt0s)
thanks guys....i forgot to bring home my last t-joints. instead of doing 1 dip with the filler i dipped twice. the weld in general had no contamination at either ends but the bead wasnt as consistant but still good. passed those. we just jumped into tube to plate. wow did it hand me my ***. tomorrow will be my 2nd day so ill bring some home and show you pictures. im doing it while standing up and its vertical. its like a 360 butt joint and i cant touch the peice of jig...just my body and arm. basiclly am starting and stopping. ;p
Old Sep 11, 2006 | 04:36 PM
Loved
Community Favorite
welp here was my best tube to plate and wow...i wanted to make some stuff for my car later on down the road...at this rate doing a header to the flange seems like its gonna be a bitch
Old Sep 18, 2006 | 12:03 AM
9295EJ-t's Avatar
are you using a high frequency 2 step?
if so.. ease into the heat, and wait for the puddle to get to the size you want it.. if it starts to get too hot, back off the pedal..
Old Sep 18, 2006 | 07:30 AM
dave@passenger's Avatar
On those pipe to plate pictures I think your tungsten is too far away from the material. Thats what I found the trick to be welding tube/pipe to plate, while you are moving around the base you need to twist your wrist so that the tungsten maintains the same distance fromthe work as when you started, the further your tungsten is away from the work the wider arc/bead you are gonna get like that. Those welds are really ugly, but your t joint and lap ones are not bad, so keep up the good work and you will get it. Just practise practise.
Old Sep 23, 2006 | 03:52 PM
EK9Greg's Avatar
Default Re: UPDATE: 9/7 first of tig welding (mynameisjustin)
not too bad at all but try puttin some pieces together and test how strong you are gettin your welds and that gives you time to make kool stuff right hahaha good luck man nice work
Draggin99Si
May 29, 2013 11:30 AM
barroom hero
Sep 14, 2004 08:26 PM
DIY_Racing
26
Oct 30, 2003 10:33 AM
Pritos
Dec 9, 2002 04:18 PM
chrisfoo
Aug 30, 2001 04:55 PM
