Map Sensor Problem
Old Aug 30, 2006 | 12:49 PM
eth0r's Avatar
Default Map Sensor Problem
I just swaped in my built b16 into my 89si, everythings working good.. since im using a obd1 throttle body on my aebs im not sure which map sensor to use, the one on the firewall or the tb, i cut and extended the wires to test them both, either or when used the car will idle at 2k, but as i was streching the green/white wire came undone and lowered the idle to a nice 800rpm but the engine light will come on showing map sensor, but if i hook it back up it spikes back up to 2k? could both my map sensors be shot, whats causing this to happen... thanks
civicEX1995
68
Jan 13, 2012 11:15 AM
bodiez
Oct 26, 2010 02:17 PM
AVATAR
Dec 14, 2002 05:14 PM
comptechgsr2000
May 8, 2002 03:53 PM
