Radiator Upgrade for 6th Gen Coupe 98-02
Old Aug 30, 2006 | 04:36 AM
AFAccord's Avatar
Default Radiator Upgrade for 6th Gen Coupe 98-02
I'm sure it's been covered somewhere, but my searching has revealed nothing. Is there an aftermarket radiator upgrade available or a model that's conformable to a 6th Gen Accord Coupe?
Old Aug 30, 2006 | 04:40 AM
YeuEmMaiMai's Avatar
Default Re: Radiator Upgrade for 6th Gen Coupe 98-02 (AFAccord)
There is a company here called universial radiator that might have a beffier rad for the car.
what you doing that requires a large rad?
Old Aug 30, 2006 | 04:45 AM
AFAccord's Avatar
Default Re: Radiator Upgrade for 6th Gen Coupe 98-02 (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">what you doing that requires a large rad?</TD></TR></TABLE>
Thanks. See my Sig. I'd just like to see my options and price them. Possibility of more efficiency and more under-hood room.
Old Aug 30, 2006 | 11:48 AM
philadd's Avatar
Someone once mentioned that a 5th gen aftermarket radiator fits, but I don't remember what brand or what modifications were needed. I do remember it didn't take much to get it to fit.
I believe it was someone who has/had a 6th gen turbo that mentioned it...
Old Aug 30, 2006 | 11:55 AM
cantaffordaccord's Avatar
Default Re: Radiator Upgrade for 6th Gen Coupe 98-02 (philadd)
it was stinker504 and it was for a 5th gen they had to modify the mounting brackets a little but it fit fine afterwards
Old Aug 30, 2006 | 01:18 PM
stinker504's Avatar
Yep, I used the 5th gen fluidyne radiator in my 6th gen with very little modification. You just have to extend the top two mounts down about 1.5". You also have to notch out the bottom bracket to clear the new drain plug.
Here is a link to my semi write up. http://www.everything-honda.co...age=2
Old Aug 30, 2006 | 07:51 PM
AFAccord's Avatar
Default Re: (stinker504)
Thanks guys. I can't get to stinker504's link from here, but as soon as I can get to some un-filtered internet access, I'll take a look.
pprowler6
Apr 2, 2008 12:59 PM
KW2000
Oct 27, 2003 09:29 PM
jester
Mar 13, 2003 08:07 AM
