crankshaft wanted
well topic says it all i guess, but what options do i have for after market brands? a new oem costs almost a 1000$
have any of you stroked the c5 engine?
a spun road bearing made the old crank into a wall decoration
wuhu
wuhu
I would only run an ITR crankshaft if I were using cast pistons. If you are using forged pistons then there is no need for the larger counter weights found on the ITR crankshaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">I believe the R crank is a bit heavier, no? I think its like 5-10 lbs. heavier....</TD></TR></TABLE>
Heavier, yes.... 10 lbs, nooooo. I weighed them side by side back in the day, god knows where i have that written down.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I would only run an ITR crankshaft if I were using cast pistons. If you are using forged pistons then there is no need for the larger counter weights found on the ITR crankshaft.</TD></TR></TABLE>
Can't say i really understand where your logic is coming from, nor agree with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBo Racing »</TD></TR><TR><TD CLASS="quote">id put a ls crank in there and get it blue printed and balanced again. then u would have a home made stroker kit. ull make some good power that way</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard »</TD></TR><TR><TD CLASS="quote">I would only run an ITR crankshaft if I were using cast pistons. If you are using forged pistons then there is no need for the larger counter weights found on the ITR crankshaft.</TD></TR></TABLE>
SWED
+ kumkuat
IBZ!
1MDMiar
LMFAO!
my head a splode...chips and salsa had better advice.
SWED
+ kumkuat
IBZ!
1MDMiar
LMFAO!
mine did not take so much abuse :s
i was thinking of forged pistons, but in this little hillbilly country like norway is it hard to find a good engine builder.
does eagle have the a crank with 87.2mm stroke?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXnorway »</TD></TR><TR><TD CLASS="quote">does eagle have the a crank with 87.2mm stroke? </TD></TR></TABLE>
Yes.
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran »</TD></TR><TR><TD CLASS="quote">my head a splode...chips and salsa had better advice. </TD></TR></TABLE>
god i miss the days of sarcastic response after sarcastic response...... it is fairly amusing that this forum is still littered with brainiacs...
euclid
10
Dec 21, 2004 05:46 PM
