GSR swap running now, idles at 3K, check engine light
Old Apr 27, 2002 | 03:48 PM
CivicEx95's Avatar
Default GSR swap running now, idles at 3K, check engine light
Finally got it running. Fired right up, and the check engine light comes on. It's idling below 1K and the car is cold. After it warms up, take it for a drive. All is good, but in neutral, its idling between 2-3K!
Tried jumping the pins, and getting the ECU codes, but the engine light is just solid, doesn't flash at all. Reset the ECU, started the car, came back on, tried checking again, same thing.
So, am I not checking the codes correctly? Whats the deal with the idle? I'm so close to having a working hybrid! Thanks everybody so far.
Old Apr 28, 2002 | 02:27 AM
Kamin's Avatar
Default Re: GSR swap running now, idles at 3K, check engine light (CivicEx95)
take off and clean the idle air control valve (underside of intake manifold, near throttle body if im not mistaken, someone confirm this)
c-reg
Dec 28, 2008 12:21 PM
viciousef9
Jun 14, 2007 03:49 PM
dingusjt
Oct 16, 2003 09:18 AM
HybridGSR1
Oct 6, 2003 07:32 PM
