rear swaybar and spring rate question
Hey, I drive a 94 del Sol VTEC (EG2) with progress springs and a suspension techniques rear swaybar.
The spring rates are 300f/175r
should i be worried about subframe tearout with the 19mm bar on an eg subframe with a 175 rear spring rate?
Is it a streetcar or are ya using it for autocross and trackdays? I'd think unless you're beating the hell out of it on the track it's not a likely problem. Or unless for some reason there's a lot of rust on the "subframe".
ActiveAero
Oct 4, 2002 08:22 AM
