'91 Teg Crank but no start with Check engine light and flashing S3 light???
Old Aug 29, 2006 | 10:15 PM
G-Money1005's Avatar
Default '91 Teg Crank but no start with Check engine light and flashing S3 light???
Greetings, I recently acquired a '91 Integra LS auto trans from my big sis. 224,000 miles and it runs like a champ... until I went to run out to the store tonight. I get a turn over, but it won't start. When I turn the key to the on pos. the check engine comes on (no pauses) and the green S3 light flashes on the gear indicator on the gauge cluster. After about five sec. the check engine light flashes off then on accompanied by a loud click from under the dash. Tried the ecu reset, checked all fuses and relays. Only have had the car a couple weeks, but big sis never had any electronic or ignition issues. I did roll it back earlier in neutral to clean the wheels and then put it back into park. Don;t know if this may have caused the issue. Any help out there???
Old Aug 31, 2006 | 06:44 PM
CASTUDILLO01's Avatar
Default Re: '91 Teg Crank but no start with Check engine light and flashing S3 light??? (G-Money1005)
CHECK FOR SPARK. MAYBE THE IGNITION COIL OR IGNITER GONE BAD.VERY COMMON ON OLDER TEGS TO GO BAD. IF YOU ARE GETTING SPARK CHECK FOR FUEL. MAY BE FUEL PUMP RELAY OR PUMP ITSELF.
bayoufox
Apr 16, 2013 05:04 AM
fsjeep
Jun 28, 2009 03:10 PM
j0sh
Apr 16, 2007 06:54 PM
civicgeek133
Apr 11, 2006 06:34 PM
