axel removal
I didn't know where to put this question. But you can move it if you want. Ok here is my question i bought a 91 si tranny, but on one side the axel hub is stuck in there. I tryed to pry it with a prybar but it still didn't move. is the axel hub part stuck in there? Or is the tranny worthless and i should try and find a new one?
the tranny is off of the motor all ready. i will try and pry it harder. One more question can i use my dx clutch on the si tranny or do i need the si one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm206 »</TD></TR><TR><TD CLASS="quote">the tranny is off of the motor all ready. i will try and pry it harder. One more question can i use my dx clutch on the si tranny or do i need the si one?</TD></TR></TABLE>
DX clutch for DX trans.
Si clutch for Si trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
Si clutch for Si trans.</TD></TR></TABLE>
Wrong.
88-89 clutches for 88-89 trannies.
90-91 clutches for 90-91 trannies.
Wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Wrong.
I stand corrected!
</TD></TR></TABLE>I stand corrected!
spray some PB blaster on and inside as much as u can. then use ur pry bar and put a huge poll on the end for leverage. then pry. u might have to find a way to hold the transmission still
Wrong.
wrong again
88 clutch for 88 transmission
89 clutch for 89-91 transmission with 88-89 flywheel
90-91 clutch for 89-91 transmission with 90-91 flywheel
Wrong.
</TD></TR></TABLE>wrong again
el arbi
Apr 21, 2003 08:14 PM
