motor mount question.
Old Apr 27, 2002 | 02:49 PM
verseone's Avatar
Default motor mount question.
i know its a dumb question, but how do i replace my front motor mount for my d series motor? i just bought the part from honda and i gotta replace mine....thanks
Old Apr 28, 2002 | 11:35 AM
verseone's Avatar
Default Re: motor mount question. (verseone)
anyone?
Old Apr 28, 2002 | 12:03 PM
flat-blk-HB's Avatar
i will tell you how i replaced mine but there might be a better way.ok first i pulled my rad. fan out for access to the top bolt.ohh by the way use a jack to lift up on the motor.put a 2x4 b/w the jack and the oil pan and release tensoion on the mounts.there is only 3 bolts i believe, one in the middle of the mount, and 2 attached to the tranny, jsut uinbolt them and pull the mount off and put the new mount back on. easier said then done i am sure.but it is not super hard.
Old Apr 28, 2002 | 12:04 PM
Malgerus's Avatar
Which side is it? if it's the driver's side, loosen the two big nuts on the top, place a floor jack under the oil pan to support the engine, and remove the mount. You might want to use liquid wrench. (My motor mount was so stuck on it took an air chisel to get it off. An air ratchet couldn't do it!).
97C1V1C
Sep 14, 2010 07:44 PM
Speed Infliction
Feb 10, 2007 09:20 AM
SpoolinEK9
Sep 18, 2004 10:39 AM
Btothe3rdDegree
Aug 18, 2004 03:47 PM
