Brake problems
when you go to brake the pedal goes to the floor right??? ...... my question is does the pedal come back up and get stiff when ur done stopping........ for example your coming up on a light u hit the brake the pedal goes to the floor and u stop then the pedal slowly comes back up
I asked if you had changed the pads recently because if you blead the brakes afterward, it could have finished of the master cylinder seals. You probably have a bad master cylinder.
http://hondaaccordforum.com/Di...m.htm
if you need to replace the brake master cylinder .....
http://hondaaccordforum.com/HO...m.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH »</TD></TR><TR><TD CLASS="quote">I asked if you had changed the pads recently because if you blead the brakes afterward, it could have finished of the master cylinder seals. You probably have a bad master cylinder.</TD></TR></TABLE>
Amen to that, I found out the hard way last week. Bench bleeding the master cylinder is a bitch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ihatecars »</TD></TR><TR><TD CLASS="quote">
no its not
</TD></TR></TABLE>no its not
scubacamper
Nov 3, 2013 09:43 AM
sobey
Mar 11, 2009 06:08 PM
