Fixed my tranny today... hell yeah (bandwidth intensive)
As you all may know my motor was replaced and when i got it back from the dealer, the tranny linkage was sloppy as a 5 dollar *****. Turns out the 3 bolts that hold the gear change holder assembly to the case (see pics below). Tighten them up, put the case back on and she is good to go
Here are some pictures.
VX1's pwn j00.
Thanks buttcoin, one of your shots is rite what i needed. I figured out what was wrong with mine, when I get it back together I'll post up.
My GSR transmission weighed about 95 lbs in a box filled with styrofoam padding. Thanks for the look at your transmission innards AssPenny, I'm currently rebuilding my GSR and you've given me an image to look forward to!
[Modified by drumsy, 8:38 PM 4/27/2002]
FD was already in there...just had to fix the slack in the shifter, which was due to the loose bolts....
We did, however, swap out his fly, clutch and JDM header/cat today too...
Great pics. If you have some time can you point some things out on some of those pictures? Like the main shaft and the counter shaft, each gear, including reverse, the final drive, the shifter forks, the dog gears and syncros, and anything else I forgot. Oh, and what is the small, straight-cut gear sitting by itself on its own little shaft? Is that part of reverse?
Thanks,
-Floyd, who is learning a lot about transmissions from these pics.
Thanks,
Hell Yeah.... we are fawking wrecked.... we just got back from a kick *** party where i threw up a few times
OMG we are done, going to sleep, I'll do a tranny layout pic with each gear in a little bit. Going to bed.... bed goood......
Craig - Who is our of his mind right now, but glad to be home, even though its spinning really bad
OMG we are done, going to sleep, I'll do a tranny layout pic with each gear in a little bit. Going to bed.... bed goood......Craig - Who is our of his mind right now, but glad to be home, even though its spinning really bad
Spoon Calipers with Lepracy. Nice
Is that Matt under the car?
As for the guy under the car. That is the man and the mistery him self, Mister Matt (D). Here is another picture of his bald *** (btw, bar is for sale, FS ad coming soon) What a queer boy...
j/k Thanks for all the help
[Modified by AssPenny, 3:58 AM 4/28/2002]
Yea, this is what happens when you lets some fawkers pressure clean the crap out of your junk. My back calipers are silver also
"Just call me Peter Pan"
Hell yeah, fun time as always.
-Marc ------> who sports the Burn it to the Ground sticker
Buttcoin, that your garage?
sack-who is also sporting the spoon fw/exedy combo
[Modified by sackdz, 4:40 PM 4/28/2002]
