do ITRs use b16 headstuds?
Old Aug 29, 2006 | 12:44 PM
kaj's Avatar
kaj
Default do ITRs use b16 headstuds?
nothing found in a search. i checked AEB's site and they only list b16/b18 headstuds... not details.. thanks.
flame on
Old Aug 29, 2006 | 12:54 PM
BlueR's Avatar
Default Re: do ITRs use b16 headstuds? (kaj)
the correct application headstuds to buy for an ITR is "B18C"
uses the same as a GSR...
DO NOT buy B16a application
Old Aug 29, 2006 | 01:01 PM
Jon D's Avatar
Default Re: do ITRs use b16 headstuds? (BlueR)
^^^er'yup
Old Aug 30, 2006 | 12:00 PM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">the correct application headstuds to buy for an ITR is "B18C"
DO NOT buy B16a application</TD></TR></TABLE>
ah. i was taking deck height into consideration. this mean i can't use my old ones. eh. thanks. 'good thing i asked before trying.
Old Aug 30, 2006 | 01:00 PM
.Thomas's Avatar
you shouldent re-use them anyways, right?
Old Aug 30, 2006 | 01:10 PM
BlueR's Avatar
Default Re: do ITRs use b16 headstuds? (TanCar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar &raquo;</TD></TR><TR><TD CLASS="quote">you shouldent re-use them anyways, right?</TD></TR></TABLE>
stock headstuds should never be re-used as they will stretch...
aftermarket such as ARP, AEBS, etc. can be re-used if you must and are in a bind as they do not stretch
Old Aug 31, 2006 | 07:12 AM
kaj's Avatar
kaj
you do not want to reuse stock head BOLTS. studs are meant to be reused. that's why i always install them if the head comes off for any reason. why buy new head bolts over and over when you can buy one set of studs for slightly more???
besides. studs are supposed to be stronger and give you peace of mind.
Old Sep 2, 2006 | 07:51 AM
Heretic:Si's Avatar
you can reuse stock head BOLTS. we do it all the time at work and have never had a problem. although if/when my head comes off i'll buy studs.
Old Sep 3, 2006 | 11:58 AM
kaj's Avatar
kaj
Default Re: do ITRs use b16 headstuds? (Heretic:Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si &raquo;</TD></TR><TR><TD CLASS="quote">you can reuse stock head BOLTS. we do it all the time at work and have never had a problem. although if/when my head comes off i'll buy studs. </TD></TR></TABLE>
head bolts are torque to yield. if you want to reuse them, it's your prerogative. if you are staying N/A, as opposed to F/I then it can be done. nobody i know would suggest it, but it is your decision.
Old Sep 3, 2006 | 04:25 PM
Heretic:Si's Avatar
actually honda has a certain torque spec for when you reuse them, so obviously you can. king motorsports told me that if i got my valvetrain done there that i should just reuse my stockers instead of arp's
Old Sep 4, 2006 | 04:07 PM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si &raquo;</TD></TR><TR><TD CLASS="quote">actually honda has a certain torque spec for when you reuse them, so obviously you can. king motorsports told me that if i got my valvetrain done there that i should just reuse my stockers instead of arp's</TD></TR></TABLE>
like i said: up to you. i just don't want to reuse them on a 10:1 motor running 13psi of boost.
also, to clear up my "use my old ones" statement, i was referring to some AEBS B16 headstuds i used to have.
Old Sep 5, 2006 | 03:46 PM
kaj's Avatar
kaj
UPDATE!!:::
i keep getting mixed info on which studs to use. AEBS rep said b16.. then he said, "what was i thinking? you need b18".
B18 are on the way. hell....
Modified by kaj at 7:01 PM 9/6/2006
DA_JDM
Aug 29, 2007 03:24 PM
lilsicsoul
12
Aug 5, 2007 02:35 AM
rex_racer728
Jul 2, 2005 03:53 PM
1hotcivicSi
13
Mar 22, 2004 08:19 AM
Outkast_CL9
Oct 14, 2003 10:42 PM
