The Phil and I have a question regarding suspension... quick answer appreciated
This is what I know...
On the fifth-generation Preludes, the suspensions from a base-model and a Type-SH will swap out perfectly, just as long as you change both the dampers and springs are replaced at the same time.
Also, I noticed ( on Tein's website ) that the part numbers for the BB4 (fourth-generation Prelude ) and the BB6 ( fifth-generation Prelude ) are the same, meaning that the suspensions between the BB4and BB6 should be interchangable.
So here's my question... will the suspension off of a Type-SH fit a fourth-gen BB4 or not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">Shocks will fit, but the front springs are stiffer on the BB6, so on a BB4, it will sit a little higher then stock</TD></TR></TABLE>
About how much higher do you think that it will sit? Thanks for the reply by the way.
