Anyone Using Ford Brake Fluid ?
Old Apr 27, 2002 | 12:52 PM
JSIR's Avatar
New User
Default Anyone Using Ford Brake Fluid ?
I ran out of the Motul brake fluid stuff a few months back, and the nearest supplier is about 2 hours away from me. So I substituted Ford brake fluid when I bled the brakes. A while back some auto-x guys recommended Ford brake fluid to me as being pretty decent. I remember reading some posts on here about Valvoline brake fluid being very good, but I found the Ford brake fluid had a higher dry boiling point than the Valvoline stuff from what I could see. So I went with the Ford fluid for the heck of it. I don't know the wet boiling temp of the Ford fluid (not listed for some reason), but dry is 550 F degrees DOT 3, not too shabby from what I could tell, and pretty affordable stuff. Anyone else ever run the Ford fluid or recommend it ?. I haven't felt any difference good or bad, it feels alright though through various braking situations.
Joey
[Modified by JSIR, 1:56 PM 4/27/2002]
Old Apr 27, 2002 | 01:48 PM
nsxtcjr's Avatar
New User
Default Re: Anyone Using Ford Brake Fluid ? (JSIR)
Here are the dry and wet boiling points for many of the most popular brake fluids:
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3 MINIMUM
DRY:446F -- WET:311F --- DOT4 MINIMUM
DRY:500F -- WET:356F --- DOT5 MINIMUM
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
ARRANGED BY WET BOILING POINT:
Old Apr 27, 2002 | 06:58 PM
Dropspeed's Avatar
Default Re: Anyone Using Ford Brake Fluid ? (nsxtcjr)
Joey, I have used it in the past, it is the exact same stuff as the Z-speed fluid. i now use ATE Superblue and have not had any problems, but everyone has there favorite.
Mattj
Old Apr 27, 2002 | 07:43 PM
JSIR's Avatar
New User
Default Re: Anyone Using Ford Brake Fluid ? (Dropspeed)
that's interesting Matt, I guess it must be fairly decent stuff to carry that kind of a boiling point, but there seems to be some other fluids a fair bit higher than that on the list. definitely worth trying.
Joey
Old Apr 27, 2002 | 10:27 PM
Yellow Dragon's Avatar
Ford Heavy Duty brake fluid has not failed me yet.
DC4R27
Dec 2, 2009 10:03 AM
kommon_sense
Jan 4, 2005 11:46 AM
SilverDc2
Jun 6, 2004 08:54 PM
CPR
Feb 6, 2003 07:13 PM
jdm92accord
Jan 30, 2002 09:29 AM
