94 integra power loss
Old Aug 29, 2006 | 08:24 AM
a.nalazek's Avatar
Default 94 integra power loss
I was driving doing about 65-70mph when all of a sudden I loss power. I have replaced the following parts so far, IAC valve, Throttle body, spark plugs and wires, checked compression its good, fuel pump, fuel filter and we end disconnected the cat converted and checked to see if that was clogged it wasn't. The check engine light isn't on either for us to check any codes. Do you have any ideas? The car will start but it doesn't have any power to move after running 3-5mins.
Old Aug 29, 2006 | 08:40 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: 94 integra power loss (a.nalazek)
Not sure why your car isn't running right, but why did you replace the throttle body?
Could it be a short somewhere? Something with the electrical?
Old Aug 29, 2006 | 09:03 AM
a.nalazek's Avatar
Default Re: 94 integra power loss (SlammedDC2)
I replaced the throttle body because I had a mechanic tell me that the TP sensor was bad. That part can be removed so I had to replace the whole throttle body. However, this didn't fix the problem.
Old Aug 29, 2006 | 09:19 AM
SlammedDC2's Avatar
Semper Fidelis
Sounds like it is electrical, but that is not a field I even pretend to know. Bump for you
Old Aug 29, 2006 | 11:36 AM
lqdcourage's Avatar
wouldnt want to happen to me, so bump for you.
Old Aug 29, 2006 | 05:21 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (lqdcourage)
Any help for the n00b?
Old Aug 29, 2006 | 06:29 PM
lVlemphizStylez's Avatar
Default Re: (SlammedDC2)
try changing the oil
Old Aug 29, 2006 | 06:37 PM
94_DC4's Avatar
Have you checked the timing? Maybe the motor skipped a tooth.
Old Aug 29, 2006 | 06:46 PM
Default Re: 94 integra power loss (SiRGDC)
yea maybe except the powerloss would be there the minute he starts the car...not 5 mins after when he lets it get up to temp..and the car would still move...he says it doesnt want to move
aho
Aug 7, 2013 12:51 PM
hondaracin24
Oct 8, 2010 08:39 PM
si del sol 94
18
Sep 16, 2009 07:39 PM
1996cd7jjs
Feb 27, 2009 03:04 PM
BoltonGSR
Dec 7, 2006 12:15 AM
