JDM SiR Cluster????
Does anyone know where I can get one? IF I get that I can use the electronic speedo gear instead of the cable right??? Does it light up amber or greenish?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pearl Crx »</TD></TR><TR><TD CLASS="quote">Does anyone know where I can get one?</TD></TR></TABLE>
eBAY? Someone on here? GO to japan and buy one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pearl Crx »</TD></TR><TR><TD CLASS="quote">IF I get that I can use the electronic speedo gear instead of the cable right??? Does it light up amber or greenish?</TD></TR></TABLE>
Yes, you can and MUST use the electronic speedo gear for the gauge to function. As far as how it lights up, I'm pretty sure it lights up similar to the US cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">That's got to be an aftermarket cluster kit.... I thought amber was the mAd tYtE JDM y0 color of choice.</TD></TR></TABLE>
Amber was found on EDM cluster
JDM are white
Both of those clusters are mine, i have messed with a few of them now
JDM are white
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer »</TD></TR><TR><TD CLASS="quote">eBAY? Someone on here? GO to japan and buy one?
Yes, you can and MUST use the electronic speedo gear for the gauge to function. As far as how it lights up, I'm pretty sure it lights up similar to the US cluster.</TD></TR></TABLE>
You don't need an electronic VSS for the JDM SiR gauge cluster to function (don't ask me how I know), but for best results/least amount of ghetto rigging -- get one.
As for where to find one, any Japanese importer should be able to source you one. Otherwise, just turn to HT or E-bay.
Good luck!
Good luck!
i got an SiR cluster $100 and a electronic VSS for B series $50
http://hondamarketplace.com/zerothread?id=1736228
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn »</TD></TR><TR><TD CLASS="quote">how could you tell if the cluster is cable or electric drivin? anyway to tell from the front or just check the back?</TD></TR></TABLE>
Cable always has this cable hookup in the back
You can use any electronic vss I'm pretty sure.I used a 93 civic one. I had to cut one of the mounting holes off though. But I'm still running my stock d15. I don't know if that's any different. I just don't know which pin on the ecu is for speed signal so I have a c.e.l. On. Anyone know how to fix this
jdmpnoy89
Oct 7, 2014 08:09 AM
bmoua
Apr 6, 2007 09:20 AM
honda06si
Dec 17, 2004 03:12 AM
jeremy.
14
Jan 2, 2004 05:18 AM
