Is the hondata reflash for the 06 si really worth it i like vtec up high ?
I know this reflash puts vtec lower in the rpm range and puts the redline to 8600 rpm i think but do i really need all that is it that much better to have a little more power down low in the rpm range any suggestions are welcome.
defintely worth the money I got more power all over the power ban and alot a of power at 6k rpm where it jumped like 30 hp
It only jumps 30hp in the mid-range if you have a header. You will only gain from the hondata if you have aftermarket parts installed such as a cold air intake, exhaust, and a header especially. A race header and hondata is really what opens this car up.
Modified by SpoolnG2 at 2:53 PM 8/29/2006
With the hondata reflash, will it reduce
the high end power or no or what?
Cuz I was thinking that when you pedal
to the metal, wouldn't the rpm go back to
6,000rpm and then when you up shift again,
it goes back to 6,000 rpm where there is
no vtec? Am I wrong? Please let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonness »</TD></TR><TR><TD CLASS="quote">With the hondata reflash, will it reduce
no vtec? Am I wrong? Please let me know.</TD></TR></TABLE>
You gain power EVERYWHERE in the power band with the re-flash --- the more mods the more power gained
Hondata saves the Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SergEK »</TD></TR><TR><TD CLASS="quote">
not like it really needed to be saved. i think its perfect the way it is
for now at least.........
120 miles to go before i can get pedal to tha medal
</TD></TR></TABLE>not like it really needed to be saved. i think its perfect the way it is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm30 »</TD></TR><TR><TD CLASS="quote">Can u reflash the ex?</TD></TR></TABLE>
No. Go to Hondata.com, and look at the reflash. You will see.
