HID RETRO FIT TSX PROJECTOR QUESTION. HELP ME
Old Aug 28, 2006 | 11:24 PM
B20inDCinLBC's Avatar
Default HID RETRO FIT TSX PROJECTOR QUESTION. HELP ME
So i got done doing my retro fit with the tsx projectors, and also the color mod with the two washers. My problem is that I dont see that much color at the cut off line. I always see TSX's drive towards me with their lights on and from far away, all I see if blue up until it gets closer. This is also in the bmw headlights. I'm trying to achieve that too, but can't seem to get it. Did I do something wrong?
Old Aug 29, 2006 | 05:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HID RETRO FIT TSX PROJECTOR QUESTION. HELP ME (B20inDCinLBC)
From what I've read the plastic lenses on Integra headlights take out some of the blue color at the cutoff. I don't know, because I get quite a bit of it still with my Hella bi-xenon projectors.
It might help if you wet sand and polish the lenses really well (I'm talking polish with a random orbital buffer, not just by hand) to reduce any fading, pits, scratches, etc. that could be scattering the light somewhat as it passes through the lens.
Old Aug 29, 2006 | 11:07 AM
anybody have this problem with the teg? my headlights are the aftermarket headlights with the clear lens, unlike the stock ones.
Old Aug 29, 2006 | 04:52 PM
Old Aug 29, 2006 | 04:54 PM
As a matter of fact, it is getting some nice colors. It just doesn't look like it during the day. These pictures do it's justice.
Old Aug 29, 2006 | 05:04 PM
Tornadom's Avatar
You have pretty good color already, and a nice cutoff line.
Old Aug 29, 2006 | 05:41 PM
yeah, it is. thanks
Modified by B20inDCinLBC at 6:03 PM 9/15/2006
Old Aug 29, 2006 | 08:38 PM
Community Builder
ahhh finally some pics of the insides of the aftermarket headlights. I've been wondering what they look like. Any pics of the projector bracket with the original halogen projector on there?
Old Aug 29, 2006 | 08:45 PM
IVI's Avatar
IVI
you did a great job!
Old Aug 29, 2006 | 08:58 PM
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">ahhh finally some pics of the insides of the aftermarket headlights. I've been wondering what they look like. Any pics of the projector bracket with the original halogen projector on there?</TD></TR></TABLE>
No, I dont have any before pictures. From what I see, it's much easier then retrofitting the stock mounting piece because I didn't have to do that much cutting. I did have a problem with the projectors sticking out too much using the 1 inch aluminum spacers....
It made the projector sit right inside the halo ring, so therefore I couldn't adjust the aiming. What I had to do was just get rid of the halo ring.
and it looks like this now,
Old Aug 30, 2006 | 03:32 PM
dc-lefty's Avatar
Default Re: (B20inDCinLBC)
where did you find those brackets ??
Old Aug 30, 2006 | 04:05 PM
those brackets come stock in the aftermarket headlights. they are pretty much the same as the stock brackets. Just a bit easier to modify compared to the stock ones because there's less cutting needed
Old Aug 30, 2006 | 07:08 PM
here are pics of the projectors that came in the aftermarket halo projector headlights
Old Aug 30, 2006 | 07:17 PM
iBrandon's Avatar
how the hell did u get the bolt off to release the bracket? I tryed for like an hour to get it off...but it just kept turning in cirlces and cirlces and cirlces...there was like a clip on the back that was holding it from screwing out....Props on ur HID though...clean install
Old Aug 30, 2006 | 07:37 PM
Default Re: (iBrandon)
hi
Modified by B20inDCinLBC at 6:05 PM 9/15/2006
Old Aug 30, 2006 | 08:23 PM
iBrandon's Avatar
dam wish i knew that before...haha i ended up using OEM housing and all i got off the aftermarkets were the clear lenses haha...
Old Aug 30, 2006 | 09:03 PM
bobyahead's Avatar
damn. those brackets look so much easier to retro fit compared to the oem ones. took me forever to cut out the oem projector.
Old Aug 30, 2006 | 09:08 PM
Default Re: (bobyahead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobyahead &raquo;</TD></TR><TR><TD CLASS="quote">damn. those brackets look so much easier to retro fit compared to the oem ones. took me forever to cut out the oem projector. </TD></TR></TABLE>
took me only 30 minuted to dremel out the required hole for the projectors
Old Aug 30, 2006 | 11:45 PM
mystikalstriker's Avatar
were the tsx reflectors/projectors made out of metal or plastic? sweet looking retro. makes me want to ditch my audis and go for tsx's.
Old Aug 31, 2006 | 01:08 AM
rookshot06's Avatar
nice job!! now i you jsut showed every1 how u did it haha.. good job tho
Old Aug 31, 2006 | 09:48 AM
Default Re: (mystikalstriker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mystikalstriker &raquo;</TD></TR><TR><TD CLASS="quote">were the tsx reflectors/projectors made out of metal or plastic? sweet looking retro. makes me want to ditch my audis and go for tsx's. </TD></TR></TABLE>
Its not metal, some ****. I dont know. Easy to drill through though.
Old Aug 31, 2006 | 05:34 PM
Default Re: HID RETRO FIT TSX PROJECTOR QUESTION. HELP ME (rookshot06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rookshot06 &raquo;</TD></TR><TR><TD CLASS="quote">nice job!! now i you jsut showed every1 how u did it haha.. good job tho </TD></TR></TABLE>
haha, yeah, you might be right. But those pics are not the final pictures of the install. There were lots of adjustments. If you guys with the DC wanna copy the exact same, then I can guarentee your lights will come out cocked-eye. = ) I saved some info to myself to keep some leaverage.
Old Sep 7, 2006 | 03:02 AM
integcraze's Avatar
Wow, i also got the tsx retro with color mod. The color didn't go thru the lens for some reason. Like you stated there not enuff color at the cutoff. Same here with my stock headlamp. I thought the aftermarket might be better because it clear but nvm. Seem like integra don't have color cutoff as nice as when the projector are out.
Old Sep 7, 2006 | 09:14 AM
Default Re: HID RETRO FIT TSX PROJECTOR QUESTION. HELP ME (integcraze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integcraze &raquo;</TD></TR><TR><TD CLASS="quote">Wow, i also got the tsx retro with color mod. The color didn't go thru the lens for some reason. Like you stated there not enuff color at the cutoff. Same here with my stock headlamp. I thought the aftermarket might be better because it clear but nvm. Seem like integra don't have color cutoff as nice as when the projector are out. </TD></TR></TABLE>
Well, i'm going to be upgrading to a better wire harness. Hopefully, it makes it brighter.
Old Sep 7, 2006 | 09:15 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20inDCinLBC &raquo;</TD></TR><TR><TD CLASS="quote">Well, i'm going to be upgrading to a better wire harness. Hopefully, it makes it brighter.</TD></TR></TABLE>
Highly doubtful. The only thing that changes the brightness of HID bulbs is to change the wattage (and current) drawn by the ballasts.
