SOHC PARTS!!!! EK and EG!!! (also DA cluster) 56K BEWARE!!!!!!!!!!
Old Aug 28, 2006 | 10:16 PM
Nicaraguense13's Avatar
Default SOHC PARTS!!!! EK and EG!!! (also DA cluster) 56K BEWARE!!!!!!!!!!
Bunch Of SOHC D16y7 Parts and d15b7 EG sohc block and head
hit me up 2019939165
Selling
96-98 Civic
1 stock headlights - sold
2 Stock Grill - 15
3. Raditor Fan- 15
4 Obd 2 Dizzy - 40
and a OBD1 Plug Cut-20
5 Alternators obd 2-50each (Have 2)
6 Tranny from a D16y7 - 150 (only been 2 months with TRANNY)
7.Sohc Flywheel off a D15b7- 25
8. Sohc Starter - 40
9.axles-30 each
10 D16y7 sohc Head - 50
11 (2) obd1 Intake Manifold without sensors- 30- with sensors-45 (have 2 Of these)
(1) OBD2 d16y7 Intake Manifold with out sensors -35 with- 50 (only one)
12 i have a 97 ECU and a 98 OBD2 P2E - 100 (Each)
the Small One is a 96 P2E - 85
THIS IS THE 96 Sticker
This is the 97 and 98 STICKER (same on both)
13. Also have a 92-95 EG sohc block d15b7 with head-no starter alternator has only 45 k been laying around my garage NOT OUTSIDE in a garage selling it for $125 came from Engine Depot mint no Echaust manifold or Intake
16 also have a couple of fuel rails like 2 or 3 have to check and Injectors as well Injectors 10 each Rail 15
17 SOHC SHIFT LINKAGE-35 (NO shifter)
No PIC right now
18 Bought a Gasket KIt Only used the Head Gasket Intake and Exhaust everything else is their For valves and Cover gasket ETC. since i payed 80 and i took the big gaskets 15 for the kit
19 Also have a Vtec Soleniod SOHC -50
20 SOHC Valve COver-15
21 Have a d16y7 Block and Head (the Crank Bearing is DOne on the Block)
If anyone wants the BLOCK to rebuild it ill let it go for $75
ALSO HAVE DA CLUSTER
i have alot of things hit me up
if anyone needs anything else from a d16y7 off a 98 ek
2019939165
Modified by Nicaraguense13 at 2:12 AM 8/29/2006
jdm-ek-si
Dec 19, 2007 07:49 PM
Nicaraguense13
Northeast (Sales)
13
Sep 17, 2006 07:01 PM
