Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Neuspeed strut bar.
Old Aug 28, 2006 | 08:41 PM
Miracle's Avatar
Default Neuspeed strut bar.
Just ordered from Dezod Motorsports. Was wondering if you guys have had installation/fittiment issues with it?
Old Aug 28, 2006 | 10:07 PM
YouGotHacked's Avatar
Default Re: Neuspeed strut bar. (.Red.EM2)
Some people on 7thgen have mentioned having to jack up one side of the car to make it fit. Isn't that big of a problem. Nothing compared to what I had to do to get my DC strut bar to fit.
Old Aug 28, 2006 | 10:26 PM
tougEMII's Avatar
is neuspeed considered a good strut bar?
Old Aug 28, 2006 | 10:38 PM
funz0rzies's Avatar
Default Re: (tougEMII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tougEMII &raquo;</TD></TR><TR><TD CLASS="quote">is neuspeed considered a good strut bar?
Yes. Solid bar.
Old Aug 29, 2006 | 02:59 AM
Miracle's Avatar
Default Re: (funz0rzies)
But if you jack up on side of the car to install it, when you undo the tophat bolts on the shock tower KABOOM, it falls out.
That is 7thGen for you.
Old Aug 29, 2006 | 04:02 AM
fventura03's Avatar
i installed it, it takes a bit of persuading, but it'll get in there eventually. i didn't need to jack up my car.
good bar, owned a polished in the past, now black.
Old Aug 29, 2006 | 07:15 AM
UNBRE4K4BLE's Avatar
Default Re: (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">But if you jack up on side of the car to install it, when you undo the tophat bolts on the shock tower KABOOM, it falls out.</TD></TR></TABLE>
I had to jack up the driver's side to get it on there. You're only undoing 2 of the nuts, so it doesn't fall out.
It's a nice bar. I'm very happy with it.
Old Aug 29, 2006 | 07:29 AM
Miracle's Avatar
Default Re: (Mars Blackmon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">i installed it, it takes a bit of persuading, but it'll get in there eventually. i didn't need to jack up my car.
good bar, owned a polished in the past, now black.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mars Blackmon &raquo;</TD></TR><TR><TD CLASS="quote">
So nothing bu good things. Cool. I will keep you guys updated, and post a DIY with pics for those that are interested.
It is the black one though. Im not trying to bliong out my engine bay. See my DIY Intake post
Old Aug 29, 2006 | 08:02 AM
03EM2guy's Avatar
make sure ur on a flat level ground when you install it........when i put mine on i had to stretch a lil bit but nothing bad at all ......piece of cake ....10min maybe
and it does wonders, i could tell a big difference around turns ...after that i needed to get something for the back ...i got a megan racing upper strut bar ...pretty satisfied w/ that too
neuspeed strut bar
Old Aug 29, 2006 | 08:32 AM
Miracle's Avatar
Default Re: (03EM2guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03EM2guy &raquo;</TD></TR><TR><TD CLASS="quote">that i needed to get something for the back ...i got a megan racing upper strut bar ...pretty satisfied w/ that too
neuspeed strut bar </TD></TR></TABLE>
Cool. See, I already have a thicker rear sway, so I am hoping this thing will work WONDERS for the front end. it just feels way too sloppy for me right now up front compared to the rear.
Springs and shocks are next!!!
Old Aug 29, 2006 | 11:59 AM
Not planning to get a thicker front swaybar at all?
Old Aug 29, 2006 | 12:04 PM
Miracle's Avatar
Default Re: (01HonderCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01HonderCivic &raquo;</TD></TR><TR><TD CLASS="quote">Not planning to get a thicker front swaybar at all?</TD></TR></TABLE>
I have heard it causes undue oversteer, so I am going to hold off. If the front strut bar tightens up the front end to my liking, then no, it won't be replaced. Ill just throw some bushings and links in there and call it a day.
But if not, then It will be replaced with the 27mm one from Progress.
Old Aug 29, 2006 | 01:11 PM
tougEMII's Avatar
i think u heard wrong...having a bigger front swaybar will cause understeer. imo i wouldnt get a bigger front sway unless u get a bigger front rear..but yeah thats how my setup is right now..rear rsx sway and springs/struts...handles fine but the front as u said is a little sloppy...
Old Aug 29, 2006 | 01:26 PM
fventura03's Avatar
friend got progress front sway, his car over steers like crazy. i don't recommend ti.
Old Aug 29, 2006 | 02:40 PM
Miracle's Avatar
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">friend got progress front sway, his car over steers like crazy. i don't recommend ti.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tougEMII &raquo;</TD></TR><TR><TD CLASS="quote">i think u heard wrong...having a bigger front swaybar will cause understeer.</TD></TR></TABLE>
So which is it, over or under?
Old Aug 29, 2006 | 03:10 PM
ragingSPAM's Avatar
neuspeeds are good...i never had to jack up any car to install it...ever car i did (which was a new bar) it required a lil elbow grease...just a lil push and it'll pop right on...and its very stiff
Old Aug 29, 2006 | 03:50 PM
Soft Swaybar on the rear, Hard on the front will cause understeer in a FWD car
Hard swaybar on the rear, Soft on the front will cause oversteer
Basically whichever end you want to grip the road better (Front/back), that's the one that you make softer
Old Aug 29, 2006 | 10:57 PM
tougEMII's Avatar
basically what i said....harder sway bar means bigger sway bar....bigger front sway means understeer...thats bad however...daily driving, bigger front sway would probably feel more comfortable. imo, id rather oversteer then understeer in any day of my life
and jus to make sure...oversteer is when ur rear swings out..understeer is when ur turning in but heading towards the outside of the turn..jus to make that clear
Old Aug 30, 2006 | 04:00 AM
Curiouz_G's Avatar
if you get a larger front sway, it cancels out what the rear sway is doing. plus, like tougemII said, oversteer is SOOO much safer than understeer.
Old Aug 30, 2006 | 10:18 AM
Default Re: (Curiouz_G)
Car manuafcturers build in a certain amount of understeer into cars, because most people who aren't good at driving freak out when the *** end gets loose
Old Sep 1, 2006 | 08:49 AM
03EM2guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01HonderCivic &raquo;</TD></TR><TR><TD CLASS="quote">Car manuafcturers build in a certain amount of understeer into cars, because most people who aren't good at driving freak out when the *** end gets loose</TD></TR></TABLE>
like me when i totaled my 2002 civic b/c of over correcting (raining also) A LOOOOOOONNGGG time ago .....yea now i prefer oversteer
Old Sep 1, 2006 | 10:14 AM
tougEMII's Avatar
yeah that is also why some civics like the 01-02 7th gens come with a huge front sway bar*25.4mm* then from 03+ we come with a nice 15.9mm ..jus like me IMO i think if u had an 01-02, i would focus more on the rear suspension rather then the front..since u have such a big sway bar in the front u wont need to much help with chassis stiffening there. but yeah..neuspeed yaAHHHHHHHHHHHHh
s2k_boy
Honda S2000
Oct 4, 2005 07:05 PM
crx_ef8
Jun 26, 2003 12:25 AM
fresh99si
Mar 25, 2003 03:13 PM
sloaccord96
May 15, 2002 09:18 PM
BlueG3Teg
Dec 9, 2001 02:19 PM
