boost question??
Old Aug 28, 2006 | 08:39 PM
SHUTTLE's Avatar
Default boost question??
can it be done ... a JACKSON RACING super charger and small TURBO work together ? super turbo.. just a thought im really a allmotor guy but just a thought
Modified by jdmshuttle at 1:32 AM 8/29/2006
Old Aug 28, 2006 | 11:44 PM
crxnj's Avatar
Default Re: boost question?? (jdmshuttle)
theres actually a guy on here that did that...He used a jrsc and a gt30 turbo,,he had it so that the supercharger boosted at idle to low revs,,and once the turbo spooled it bypassed the supercharger ..So you got both response,low end tq,and high end power,,basically a sequential setup ...but this type of thing isnt just slapped together..i'll see if i can find the link
Old Aug 28, 2006 | 11:50 PM
93formula's Avatar
Default Re: boost question?? (Mr.speaker)
i remember that, it was a looooong time ago, but in the end its not worth it unless you got money to burn and just want a crazy looking setup. if not done correctly you can overspin the jrsc and ruin it.
Old Aug 29, 2006 | 12:32 AM
SHUTTLE's Avatar
thanks. i might try this. its not going to be for a drag car its going to be for a auto X car. i think i will use a small turbo. what do you think 3-4 lbs max??
Old Aug 29, 2006 | 06:54 AM
Loserkidwac's Avatar
Default Re: (jdmshuttle)
Its called twin charging, not very common with Hondas but I have seen it on a few MR2s if you are going to run a smaller turbo you are just going to be hurting yourself, there will be no possitve gains, the reason for twin charging was to make boost instanly with the supercharger to help spool up the turbo, it isn't a simple let slap on a turbo and a SC, you better gt your calulator out and do some math to make it work properly and not have either choking the other out, cool idea but not worth the investment to make it work properly
Old Aug 29, 2006 | 10:21 AM
SHUTTLE's Avatar
i have seen it done too. on classic cars. thats why i had the idea to try it. i know the problems on this idea. but i will be doing the build with 1 of the best and fastest HONDA GURU'S around. i think i will run the idea by him see what he thinks about it.
Old Aug 29, 2006 | 10:42 AM
crxnj's Avatar
heres that link https://honda-tech.com/zerothread?id=1293497
Old Aug 29, 2006 | 10:48 AM
SHUTTLE's Avatar
thank you for your help MR. SPEAKER
B18B1-Crx
21
Apr 30, 2010 09:35 AM
stiffinEK
12
Aug 30, 2009 09:55 PM
b18c inside
Sep 14, 2005 01:30 PM
2point3h22lude
Jul 6, 2005 02:33 PM
nblock93
Feb 14, 2005 04:27 AM
