Is Jdm obd 1 gsr dist . The same as USDM ????
whatever you get make sure its a true TD-68U. I was told a td-44u from a b16 would work but it doesnt, well it does but you can only advance the timing to 8 Degress BTDC. Buy a td-68u. They are $175 shipped brand new on ebay
the plug connectors may be different, Idont know. The last used part you want on your engine is a used distributor. Man those things suck, they die all the freaking time. How can you not drop $175 on a brand new td-68u and never worry again.
the plugs and connectors are the same...they use a slightly different color coding for the wires though...if youre going from obd2 plugs on an obd2 dizzy you might have to play around to find the right sockets
honda_90
Mar 1, 2011 10:47 AM
