98 civic wont start after installling lights
Old Apr 27, 2002 | 11:10 AM
96hbdx's Avatar
Default 98 civic wont start after installling lights
I was installing some lights that required a seperate electrical source . At the same time i was listening to the radio . I was cought off guard and disconected the negative battery terminal with the ignition key on and my radio playing . NOw the car wont start and the radio dosnt work . Also the parking light fiicker once i connect the battery back up and some kind of a switch goes on and off really fast inside the car by the glove box . So i disconected the parking light fuse and now it dosnt flicker but car still wont start . Please help . My paerent are yelling at me ...... And I just got the car 3 days ago .
[Modified by 96hbdx, 8:11 PM 4/27/2002]
Old Apr 27, 2002 | 11:12 AM
The AntiRice's Avatar
Default Re: 98 civic wont start after installling lights (96hbdx)
make sure the ground is properly tightened and the terminal is clean. Possible you killed the battery listening to the radio. Does the car crank?
Old Apr 27, 2002 | 11:14 AM
flat-blk-HB's Avatar
sounds like you could of possibly shorted something out. does the car no even try to start?does the lights (headlights) work or brake lights? how long where you listein to the radio? try push startin the car.
[Modified by 89-ED-bcumbie, 2:15 PM 4/27/2002]
Old Apr 27, 2002 | 11:20 AM
96hbdx's Avatar
Default Re: 98 civic wont start after installling lights (89-ED-bcumbie)
car dosnt crank , when i put in the light fuse the parking lights flicker and a switch goes on and off .
Old Apr 27, 2002 | 11:51 AM
96hbdx's Avatar
battery is dead because of the radio and the battery fuse in the little box by the battery is fried . Switch them out from my dads car( also a civic ) and it started cranking but battery so weak that it wont start. I'll do it tomorrow because my parents are having a party today .
Old Apr 27, 2002 | 11:58 AM
dom93hatch's Avatar
Jump start it. Get some cables and jump from your dad's car or something.
Old Apr 27, 2002 | 12:05 PM
dirtySOHC's's Avatar
i hope that you learn from this........you should always disconnect the negative terminal........
Old Apr 27, 2002 | 05:40 PM
96hbdx's Avatar
Default Re: 98 civic wont start after installling lights (dirtySOHC's)
yep lesson learned . Thank god no major problems . After checking everything out we found that the battery was totally dead . Jump starting didnt help because a fuse (box by the battery) was blown We replaced it with a fuse from my dads car (98 lx) and it started to crank but battery is so weka that it would not catch all the way. The only thing is that I could have blown the radio .... But will find out tomorrow . I thought that my whole electricial system went down . God that would be a lot of $$$ to fix .
BLKOUT23
16
Nov 10, 2015 11:08 AM
Eg Fool
19
Sep 12, 2009 07:28 PM
unclebenwho
Apr 11, 2006 12:19 PM
Sbird
Nov 25, 2004 12:21 PM
96hbdx
Apr 27, 2002 07:02 PM
