93 integra died while driving
Old Aug 28, 2006 | 06:27 PM
shovelheadrabbit's Avatar
Default 93 integra died while driving
My son just put fuel in his 93 integra and drove about 6 miles when it lost power and coasted to the side of the freeway , It turns over ok but will not fire , It looks and sounds fine when turning over and he said it didnt back fire or over heat before losing power , Everything sounds tight , The car has had pretty good care and Im not to sure where to start , Anybody have a good starting place for me to check ??
Thanx , Bob
Old Aug 28, 2006 | 07:07 PM
Sam92Teg's Avatar
Default Re: 93 integra died while driving (shovelheadrabbit)
Start by checking for spark, then fuel. That will narrow down the process.
Old Aug 28, 2006 | 08:08 PM
Default Re: 93 integra died while driving (Sam92Teg)
Thanx I will look at the spark and fuel , I read alot about the ignition switch also , Thanx again , Bob
Old Aug 28, 2006 | 08:48 PM
tegswin's Avatar
ignitor? in the distributor?
my friend was merely backing my car up to pull it into a garage and it died on the spot, ignitor was the culprit. If you don't have any spark you might check that out.
Old Aug 28, 2006 | 09:10 PM
93GSRB17's Avatar
check for spark first. i've had that problem before. it could be something else but i would start there.
Old Aug 29, 2006 | 01:11 PM
B18CUL8R's Avatar
ignitor
Cav3man
Mar 24, 2012 03:44 PM
da9brotherz
Mar 6, 2011 06:35 PM
joyrider58
Jan 1, 2009 10:23 PM
93TEGGYgs
Oct 21, 2008 04:32 PM
