Removing the rear bumper?
I am trying to take off my rear bumper. I know there are the screw where the splash guards would go. There is one behind the license plate, and then two on the underside (one right above the exhaust tip and another across from that). The problem is that the screw behind the license plate will NOT come off. I tried PB Blaster and all kinds of crap.
Anyone have techniques for it?
And are those the only ones?
Thanks...
Thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by square_1 »</TD></TR><TR><TD CLASS="quote">I am trying to take off my rear bumper. I know there are the screw where the splash guards would go. There is one behind the license plate, and then two on the underside (one right above the exhaust tip and another across from that). The problem is that the screw behind the license plate will NOT come off. I tried PB Blaster and all kinds of crap.
Thanks...</TD></TR></TABLE>
I just got a big drill bit and drilled mine out 15 mins ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">remove the bumper with the support and then when you have room you can get it out somehow</TD></TR></TABLE>
there are two bolts inside the car and two under the car to remove the mount
Twigster311
Feb 24, 2004 04:06 PM
