94 accord...changing fuel/air mix newbie question
Old Aug 28, 2006 | 06:06 PM
coolrahool's Avatar
Default 94 accord...changing fuel/air mix newbie question
Sorry newbie question...Having slightly, very slight higher than normal CO2 readin,gs after taking a local emmissions test...apparently CO2 is created when there is a lack of air ....so can i not just adjust the mix adding slightly more air to ny using /adjusting the little screw that controls this? I fso how will i know which way is doing what. Adjust/turning it one way will rev up the idle -is this then adding more air to the mix is the opposite going to happen if i turn it the other way? (more air added then-higher the revs/idle speed - and less air gets mixed then lower rev/idle speed?)
Old Aug 28, 2006 | 06:41 PM
gianinline's Avatar
bump for that....
Old Aug 30, 2006 | 12:46 PM
Perfectionist's Avatar
Default Re: 94 accord...changing fuel/air mix newbie question (coolrahool)
I think what you are describing is the Idle Air screw. All it does is set the base idle speed. Your higher CO2 readings as you discovered are from a lack of air, or unburned fuel. The O2 sensor is what primarily controls the air/fuel ratio. I would investigate that first. Then, spark plugs, ignition components, air filter, timing, and what the heck, PCV valve. Also, make sure your thermostat is allowing the engine to reach the designed operating temperature.
Old Aug 30, 2006 | 05:32 PM
coolrahool's Avatar
Default Re: (gianinline)
OK Thanks i will try that
Gabriel Ale
Honda CR-V & Element
Dec 23, 2018 06:29 PM
JDMPanda503
May 7, 2010 10:11 PM
scrolanky
Nov 5, 2008 07:21 PM
cetv
Feb 14, 2006 02:06 PM
a1320honda
11
Nov 14, 2005 11:15 PM
