'03 Accord 4cyl Manual - Clutch Bleeding Procedure?
Old Aug 28, 2006 | 03:54 PM
amorak's Avatar
Default '03 Accord 4cyl Manual - Clutch Bleeding Procedure?
Hey guys,
I have a 2003 Accord DX with the k24 and manual transmission. I want to bleed the clutch fluid, but don't have a shop manual.
Myu understanding is that you simply, with the car off, pump the clutch 3-4 times until it's hard, then have someone in the engine bay undo the bleeder on the clutch cylinder, and when the pedal is getting to the floor, close it up (basically teh same as a brake bleed).
Can anyone tell me if:
1) This is right
2) Where I can find the bleeder for the clutch ?
Thanks!
Old Aug 28, 2006 | 06:19 PM
V6iCkSpEeD's Avatar
What i did was evacuate the brake fluid out of the clutch fill resevoir then refilled it with new fluid then have someone sit in the car and have someone undo the bleeder valve, you have to pump it in sequence to get all of the old fluid out or you will just use up alot of fluid, just make sure that there is fluid in the resevoir at all times.
benfromthebay
Oct 9, 2016 07:26 AM
shortlid
Apr 14, 2007 09:20 AM
return_2020
Jul 14, 2004 05:51 AM
Qwikrex
Apr 20, 2003 03:27 PM
KF_S2000
Jul 21, 2002 01:41 PM
