What did you do to your EF today?
Old Aug 28, 2006 | 03:11 PM
imgoingforit's Avatar
Default What did you do to your EF today?
The other thread was fairly nice while it lasted this winter, so I figured I'd make a new one and see what you guys have been up to. So what did you guys do to your EF today?
(I dreamed of owning one lol)
-Chris
Old Aug 28, 2006 | 03:20 PM
djphonics's Avatar
Default Re: What did you do to your EF today? (imgoingforit)
-New front brake rotors and pads - soon to be replaced again with big brake upgrade.
-Vacuumed and cleaned interior
-Rotated tires
Old Aug 28, 2006 | 03:24 PM
C_R_X_V_T_E_C's Avatar
made sweet, pasionate love to both the tail pipe and the fuel spout ( the most commonly visited hole).
i just said all this and im still not as gay as the OP
"dreamed about owning one" get a job ya fu(king hippie.
Old Aug 28, 2006 | 03:25 PM
Got_soy's Avatar
Default Re: What did you do to your EF today? (djphonics)
let it sit in the sun on the street parked, waiting 450s and a dp
Old Aug 28, 2006 | 03:29 PM
1990si's Avatar
i thought about it. im pry gonna get some k-sports susp. and a zc motor.
Old Aug 28, 2006 | 03:36 PM
madmanmulligan's Avatar
Default Re: (1990si)
i smashed my heater unit in with a sledge hammer because i was too lazy to take out the 3 screws it was funnnn
Old Aug 28, 2006 | 03:45 PM
Fezzie's Avatar
Default Re: (madmanmulligan)
thought about what i was gunna do! then looked at it imaging it a 10 sec car then i was too lazy to wash it so i ordered a 8.0lbs flywheel
Default Re: What did you do to your EF today? (C_R_X_V_T_E_C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_V_T_E_C &raquo;</TD></TR><TR><TD CLASS="quote">made sweet, pasionate love to both the tail pipe and the fuel spout ( the most commonly visited hole).
"dreamed about owning one" get a job ya fu(king hippie.</TD></TR></TABLE>
Hey man, no need to be a dick. I have a job, buddy, but some of us have to go to school too.
Continue, pics are good BTW
Old Aug 28, 2006 | 03:48 PM
Tippyman's Avatar
Wished I was fully recovered from surgery so I could get off my *** and put my Si tranny in.
Old Aug 28, 2006 | 03:49 PM
Boosted Chemist's Avatar
Default Re: (Tippyman)
Hit 15psi
Old Aug 28, 2006 | 03:52 PM
mullenite's Avatar
Default Re: (Boosted Chemist)
Looked at it, thought about starting the body work even though it still isn't running. Then thought about getting it running. Then thought about how fun it was to drive, then got mad because I had to drive the stupid RSX.
Old Aug 28, 2006 | 03:54 PM
jhota's Avatar
it's an EE, but:
drove to work.
drove to class.
drove home.
tomorrow, it's staying in the garage - i'm driving the '70 Spitfire instead.
Old Aug 28, 2006 | 03:55 PM
redzcstandardhatch's Avatar
something different
put another corbeau forza seat in, in the pass. side!
getting ready to put a diff. intercooler in, much bigger one
Old Aug 28, 2006 | 03:59 PM
xplicit ef's Avatar
took it for a drive after 3 days since friday i had to get 4 wisdom teeth pulled out felt so good driving it after so long
Old Aug 28, 2006 | 04:00 PM
e jay one's Avatar
Default Re: (redzcstandardhatch)
droped the gay *** dpfi/automatic motor on the ground (it wont fit in the garbage can) getting ready to take the pedals off fun!
Old Aug 28, 2006 | 04:10 PM
user 72830283's Avatar
can't get this fuking MPFI swap to crank over and fire...keeps throwing a cel code #16, i've checked the wiring over and over again..made sure the resistor is good...given up on it for the day will tackle it tomm. but for now any suggestions?
Old Aug 28, 2006 | 04:11 PM
Default Re: (pr3d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d &raquo;</TD></TR><TR><TD CLASS="quote">can't get this fuking MPFI swap to crank over and fire...keeps throwing a cel code #16, i've checked the wiring over and over again..made sure the resistor is good...given up on it for the day will tackle it tomm. but for now any suggestions?</TD></TR></TABLE>
What is 16(to lazy to search)? Did u reverse the tps wires? Bad dizzy?
Old Aug 28, 2006 | 04:15 PM
d16efsedan's Avatar
i looked at my motor and wished it was in my car hah..
Old Aug 28, 2006 | 04:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">What is 16(to lazy to search)? Did u reverse the tps wires? Bad dizzy?</TD></TR></TABLE>
throwing the cel code #16-Fuel Injectors? wtf does this mean? are they bad or not getting current..what the ***? sorry..just venting...sometimes you just wanna kick the son of a bitch ...o well..but the dizzy is good...checked for spark delivery..and also tried another dizzy...i did reverse the tps wires....but i can't hear the fuel pump prime when i turn the key to on...so it may be the lack of fuel..but i don't know where to start on working on that...
Old Aug 28, 2006 | 04:22 PM
Default Re: (pr3d)
throwing the cel code #16-Fuel Injectors? wtf does this mean? are they bad or not getting current..what the ***? sorry..just venting...sometimes you just wanna kick the son of a bitch ...o well..but the dizzy is good...checked for spark delivery..and also tried another dizzy...i did reverse the tps wires....but i can't hear the fuel pump prime when i turn the key to on...so it may be the lack of fuel..but i don't know where to start on working on that...</TD></TR></TABLE>
sounds like main relay if the pump isnt priming. You ran the two new wire correct and tap the old ones right? Did u wire the resistor correct?
Old Aug 28, 2006 | 04:27 PM
nudvl's Avatar
Mounted my F M I C!!! need to cut my bumper alil
Old Aug 28, 2006 | 04:48 PM
JDMister_EF9's Avatar
Default Re: What did you do to your EF today? (nudvl)
Took off my Trust exhaust and am now wondering how I'm going to get the cat to stay off of the ground...
Old Aug 28, 2006 | 04:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">sounds like main relay if the pump isnt priming. You ran the two new wire correct and tap the old ones right? Did u wire the resistor correct?</TD></TR></TABLE>
yep..injector 2 was from the plug A3..and injector 4 was from plug A4...injector 1 was the solid red from the prior dx harness..and the 3 was the solid yellow..and the rest red-black wires went to injectors..along with the 2 yellow-black wires...
Old Aug 28, 2006 | 04:57 PM
boosted.CRX's Avatar
Imagined it with the SiR face and spoiler I'm picking up in a week!
Old Aug 28, 2006 | 05:07 PM
Discontained's Avatar
Installed some HID's and set the timing, fit the hks exhaust, and shot some fireballs out the exhaust o.O
