bending ac lines
Old Aug 28, 2006 | 01:51 PM
b18c-1's Avatar
Default bending ac lines
any one do a frontend conversion on a integra with ac and trouble with the oem hid ballast hitting the vaccumm ac knobb on the driver side
Old Aug 28, 2006 | 02:01 PM
SilverDc2's Avatar
Default Re: bending ac lines (b18c-1)
hid ballast? are you guys doing a jdm front end conversion?
NO, DO NOT bEND the lines, they will get crushed.
Old Aug 28, 2006 | 02:06 PM
b18c-1's Avatar
Default Re: bending ac lines (SilverDc2)
yes oem hids, what do u suggest
Old Aug 28, 2006 | 02:08 PM
SilverDc2's Avatar
i installed my jdm front, you have to work around them, put the lights last, i dont remember clear cause it was 4 years ago.
Old Aug 28, 2006 | 02:10 PM
b18c-1's Avatar
ic ic but the the ballast is hitting the ac ****, right behind the driver side head light and its in the way hardcore
Old Aug 28, 2006 | 02:59 PM
Padawan's Avatar
Darth ModerVader
It should be possible for you to gently bend the lines to create enough clearance.
Old Aug 28, 2006 | 03:23 PM
b18c-1's Avatar
Default Re: bending ac lines (Padawan)
yeah i tried that but i have to move it 3 inches back and theres only so much u can move it before it breaks, no one else did conversion on a gsr?
Old Aug 31, 2006 | 08:13 AM
b18c-1's Avatar
so i just disconnected my ac line, is it bad for it to be open to the air
because my cel light is on and i dont know if that is what it is
Old Aug 31, 2006 | 08:36 AM
scheistermeister's Avatar
go the route im going with the bling bling SS a/c lines...
http://store.summitracing.com/...16303
http://store.summitracing.com/...w=sku
r1whore
May 26, 2015 07:30 PM
I Kick Squirrels
Aug 8, 2009 07:38 PM
CRX 2.0V-T
Oct 12, 2006 06:35 PM
b18c-1
Aug 7, 2006 08:04 AM
Type R
Sep 11, 2002 09:46 AM
