lower itr header and cat?
Old Aug 28, 2006 | 11:29 AM
silentdeath12886's Avatar
Default lower itr header and cat?
i have a dc4 99 ls cpe. i recently put on a skunk2 60mm/2.34" catback. now i want to work on the headers and cat. i know the oem header is a 2 piece and was wondering can i use the lower portion of the header direct bolt onto the ls upper header? how big is the collect on itr header? should i use oem itr cat or carsound?
Old Aug 28, 2006 | 11:35 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: lower itr header and cat? (silentdeath12886)
No and if it did it would serve absolutely no purpose. Buy a real header!!
Old Aug 28, 2006 | 04:07 PM
Padawan's Avatar
Darth ModerVader
Yes, you can bolt the lower half of an ITR exhaust manifold onto the upper half of your LS manifold. The collector is 2" OD (the same as the LS), and it will bolt right up to either an LS or ITR cat. However, if you're looking for performance gains, you really won't realize any by performing this swap.
96 Ls lnTeG
Jan 6, 2004 06:40 PM
dip-set
Jan 16, 2003 03:35 PM
Flexmyrex
Sep 10, 2002 07:56 AM
lude69
Jul 30, 2002 09:43 PM
Timmayeg
Feb 21, 2002 12:15 PM
