obd 0 codes
Old Aug 28, 2006 | 08:16 AM
GsrTurboCRX88's Avatar
Default obd 0 codes
Hey I am getting 16 quick flashes in a row. Is that code 16 cause i thought code 16 would be one long flash and six quick flashes.
Old Aug 28, 2006 | 08:22 AM
Reelizmpro's Avatar
Default Re: obd 0 codes (GsrTurboCRX88)
long flash = 10
that's how I understood it too. You sure it's 16 short flashes and not separate codes?
Old Aug 28, 2006 | 08:37 AM
Default Re: obd 0 codes (Reelizmpro)
No, it is flashing 16 times in a row. It kind of makes sence that I would be throwing a code 16 because when my car died, it really felt like i ran out of gas even though there was almost havlf a tank cause 16 is injectors
Old Aug 28, 2006 | 08:40 AM
ludesrv's Avatar
OBD0 or Pre OBD cars flash 16 times for code 16, but only certain ECUs. Mine will flash 20 times for code 20.
Look in the FAQ, there is a link to honda diagrams on how to trouble shoot that code. It's more then likely a failing main relay or a bad signal from the injectors.
Old Aug 28, 2006 | 08:50 AM
Default Re: (ludesrv)
ok well here is the deal. I just bout this car and it was not running. I put a new head gasket and new head and it ran fine. then i started hearing a loud ticking from the head . I was driving and then it died. It felt like a ran out of gas. Put some more gas in it and it ran for a while longer.
Now, it will start but when i press the gass nothing hanppens. It seams to suck in air but that is it when i press the gas. This is a 90 dx hatcback. Throwing codes 4, 6, and 16
Old Aug 28, 2006 | 09:32 AM
Default Re: (GsrTurboCRX88)
up
WhiteSOHC
Mar 21, 2011 03:31 AM
JaHnAbOi
Apr 6, 2007 01:20 PM
Dspad_91Civic
15
Jul 9, 2004 12:07 PM
brbHPR
Jun 15, 2003 05:25 PM
S13 slide
Jan 9, 2003 10:51 PM
