Doing a mini me swap just would like a couple questions answered not covered in how to's?
Old Aug 28, 2006 | 07:57 AM
Xemu's Avatar
Default Doing a mini me swap just would like a couple questions answered not covered in how to's?
Putting a D16Z6 head on my D15B2.The head is off and right now I'm in the process of trying to get whats left of the head gasket off and smoothed out.My question is how concerned should I be about scraped up gasket and metal shavings:#1-falling into the piston sleeves and any of the other cooling holes around the block surface??? Obviosly I will clean it and air blow it before mounting the head but I'm worried about crap falling into the outer cylinder walls where the coolant is??? Anybody been through this and/or have any suggestions??? Thanks
Old Aug 28, 2006 | 08:40 AM
Loserkidwac's Avatar
Default Re: Doing a mini me swap just would like a couple questions answered not covered in how to's? (Xemu)
When i do a head gasket i fill the car up with oil(Cheap oil and maybe some sea foam) and coolant(just use water) run it for say 5 min and then drain and replace both the oil, filter and coolant with some new stuff, maybe thermo too, this allows the crap to drain out and shouldn't do any damage...you can also use a shop vac and suck out the watter jacket if you want , aslong as there isn't any large peices you should be cool
Old Aug 28, 2006 | 11:16 AM
Xemu's Avatar
Default Re: Doing a mini me swap just would like a couple questions answered not covered in how to's? (Loser
So as long as I flush everything out after I should be Ok as long as it's nothing too big????
Old Aug 28, 2006 | 11:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu &raquo;</TD></TR><TR><TD CLASS="quote"> So as long as I flush everything out after I should be Ok as long as it's nothing too big????</TD></TR></TABLE>
Yup, I never had any trouble doing it this way, unless someone else has another methoid that is better but i don't really think there is...
Old Aug 28, 2006 | 11:54 AM
1990si's Avatar
i just used an air compresser and blew it all out and cleaned up what blew out with a rag
Old Aug 28, 2006 | 03:20 PM
Xemu's Avatar
Good enough...Thanks guys!!
slipyoke
Jun 17, 2012 07:22 PM
Robotin
Mar 24, 2012 04:03 PM
AccordNation
May 4, 2011 10:36 PM
jdmcivic904
Feb 28, 2011 09:31 PM
98civic4dr
Oct 8, 2005 12:30 PM
