tiny motor bracket on driver side help please!?!?!
Just a quick question!? I know it is illegal to have an older motor in a newer car, but I am helping a friend of mine put in a motor into his 94’ integra, but have an issue. The block is a b18a1 and the driver side bracket won’t line up! Any clue on where or what other motor mount would work on that?!
When we went to bolting up the motor to the car, we noticed that the tiny bracket that holds the rubber mount to the driver side is more pointed towards the front than the rear. The DA motor bracket is different than that of the newer integras. I was wondering if anyone knows if that tiny bracket from a single cam will work on that motor swap!? If not, can someone point me out the part number for that bracket from Honda or Acura? In need just that mount to have the motor set in place.
In need of the little bracket that is held by three bolts that is bolted to the side of the motor. So any help will do.
We were hoping to get this thing in by last night, but couldn’t cause of the one bracket. Thanks in advance!!!
TH33G4MON3
Aug 26, 2005 12:21 AM
