91 civic special edition 1.5 liter no compression?
Old Aug 27, 2006 | 10:24 PM
stevescivic's Avatar
Default 91 civic special edition 1.5 liter no compression?
so a friend dumped off a 91 civic special edition 4 door sedan at my house and he said that he wanted to me to see if I could fix it.
I'm quite confident that I can repair it but I would like some insight from other honda pros from HT.
I measured the compression on all cylinders after the motor warmed up to operating temp.
cylinder 1 = 180 psi
cylinder 2 = 185 psi
cylinder 3 = 0 psi (that is no typo there is NO compression whatso ever on this engine)
cylinder 4 = 180 psi.
what the heck would cause this 1 cylinder to have zero compression??
The motor still starts but obviously runs like crap.
please tell me its a simple fix like a cylinder head swap. The car has 330, 000km's and its in great shape.
My friend even said that I can have the car if it will cost him too much money to fix.
I highly doubt that its a damaged piston and I'm sure the connecting rod is still in tact since it would make an awful noise if it broke.
suggestions?
Old Aug 28, 2006 | 05:58 AM
purplecrx's Avatar
Well, 0 compression means 100% of the air is escaping from the cylinder. So.. hole in piston, completely eaten valve? Either way, it's not going to be pretty. I'd line up a different motor to install in that puppy.
Old Aug 28, 2006 | 10:03 AM
Super Chicken's Avatar
Default Re: 91 civic special edition 1.5 liter no compression? (stevescivic)
That's usually a burnt exhaust valve. put the cylinder on top dead center compression stroke and blow some air into it and listen where it comes out. If it comes out the exhaust=exhaust valve comes out the air filter than an intake valve if it comes out the crankcase=burnt piston
Old Aug 28, 2006 | 12:14 PM
1991civicsi's Avatar
Default Re: 91 civic special edition 1.5 liter no compression? (Super Chicken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken &raquo;</TD></TR><TR><TD CLASS="quote">That's usually a burnt exhaust valve. put the cylinder on top dead center compression stroke and blow some air into it and listen where it comes out. If it comes out the exhaust=exhaust valve comes out the air filter than an intake valve if it comes out the crankcase=burnt piston</TD></TR></TABLE>
Yes, this is true, the leak down test will pinpoint where the damage has occurred.
Old Aug 28, 2006 | 12:20 PM
djphonics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken &raquo;</TD></TR><TR><TD CLASS="quote">put the cylinder on top dead center compression stroke and blow some air into it and listen where it comes out. If it comes out the exhaust=exhaust valve comes out the air filter than an intake valve if it comes out the crankcase=burnt piston</TD></TR></TABLE>
+1
northcb7
Jun 8, 2009 12:31 PM
Dave_Dc2
Nov 3, 2008 06:29 PM
93H22ACX
Feb 11, 2003 04:23 PM
td04civic
Mar 3, 2002 07:55 PM
B17aTrbo
Nov 7, 2001 10:38 AM
