Radiator Fan Question
I have a 97 accord 4cyl. Just replaced my radiator, it was spilling coolant like no other. My fan was always on. Now since I have replaced the radiator, I have yet to see/hear it turn on. Is this normal? I wouldn't know how often it should turn on, due to the fact the radiator has been bad since I've owned the car. Let me know guys, thanks!
well maybe did you release the air pressure out of the thermostat housing relief valve if you didn't then ya cause it might have settled near the temp sensor and blocked the sensor from getting a good measure.
But if you did then it is probably just not clogged like the other one and is flowing better and cooling when you drive so the fan will not need to be on as much as before
buster97
Feb 17, 2016 07:11 AM
