lowering your bikes??
Old Aug 27, 2006 | 07:44 PM
VRD^don's Avatar
Default lowering your bikes??
okay guys..my bro has this bike for awhile..and it quite high for him..he has to tip toe just to ride it...the bike is a 2001 triumph 600TT...the bike has a rear coil shock..im sure most bikes comes with it..can i just adjust this so it lowers the bike or do he have to get a lowering kit for the bike..thanks.!!!
Old Aug 27, 2006 | 08:12 PM
marmaladedad's Avatar
Have him try the one-cheek-sneak first, before messing with the suspension.
Also, he might be able to shave down part of the seat.
But if you must lower it, drop the triple in the front (aka: raise the fork tubes up through the triples) to lower the front of the bike.
Old Aug 27, 2006 | 08:34 PM
VRD^don's Avatar
Default Re: (marmaladeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">Have him try the one-cheek-sneak first, before messing with the suspension.
But if you must lower it, drop the triple in the front (aka: raise the fork tubes up through the triples) to lower the front of the bike.</TD></TR></TABLE>
i really dont know much about bikes..so u have to explain what one-cheek-sneak and drop the triple in the front is..lol..
Old Aug 27, 2006 | 08:35 PM
VRD^don's Avatar
Default Re: (k_motor)
also..what do u mean about shaving down the front seats...
Old Aug 27, 2006 | 08:41 PM
One-cheek sneak means he uses only one foot at a stop. A lot of my friends are vertically challenged, and that's what they use. Altering a bike's suspension is detrimental to the handling if you do not know what you are doing.
If you look at the front forks, you will see they slide through a part of the bike. It is commonly referred to as the triple or triple tree. You can loosen the pinch bolts that hold the forks and pull the forks up, through the triples, effectively lowering the front of the bike. It will make the bike turn in faster as a side effect. This could make the bike very twitchy as a result.
Shaving down the seat means taking off the surface, shaving down part of the inside, and then putting the upholstery back on.
If it were me, I would try
1) balancing on one foot
2) shaving the seat
3) altering the suspension
Old Aug 27, 2006 | 08:48 PM
VRD^don's Avatar
cool thanks..hes already doing that one cheek-sneak thing..i'll have him try the others...thanks alot..anyone have more input??
Old Aug 28, 2006 | 08:50 AM
BusaWill's Avatar
Just get online and get some lowering links for the back you should be able to find some for like 30 bucks it will be alot better
Old Aug 28, 2006 | 09:34 AM
MSchu's Avatar
My Name is Nobody
Default Re: (BusaWill)
no it won't be better... this changes the leverage ratio and it lowers the ground clearence... if your friend is tippy toeing, he has enough touch to ride safely... if he is experienced. I only ever use ONE FOOT/toe of my boot(right foot) to stop but I have been riding for 26 years on the street. the one cheek sneak is the way to go if your friend is not comfortable in his balance.
Old Aug 28, 2006 | 10:12 AM
dao.xiong's Avatar
Default Re: (MSchu)
just bring it to ur local motorsport shop. im sure it will be less then $100 to lower the triple tree and put some links in.
Old Aug 28, 2006 | 10:31 AM
Sijray21's Avatar
Default Re: lowering your bikes?? (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">okay guys..my bro has this bike for awhile..and it quite high for him..he has to tip toe just to ride it...the bike is a 2001 triumph 600TT...the bike has a rear coil shock..im sure most bikes comes with it..can i just adjust this so it lowers the bike or do he have to get a lowering kit for the bike..thanks.!!!</TD></TR></TABLE>
they do have a lower control arm links for the swing-arm (i believe that's what it's called). I just know it as the dog-bone. They offer adjustable or ones that will lower the bike, but keep in mind that you'll need to cut/reweld the kickstand if you lower it. Lowering the bike changes the geometry of the suspension and overall handling of the motorcycle. If you're just riding it on a daily basis without pushing it, you might not even know the difference in the handling. Look around eBay or other motorcycle forums for the parts. Lowering the front through the triple forks could also help - just don't for get about that kickstand if you lower it enough. If you lower it without adjusting the kick-stand you'll notice the bike sitting very upright when you park it and it will be more likely to fall.
Old Aug 28, 2006 | 10:40 AM
Etylorcen's Avatar
Default Re: lowering your bikes?? (Sijray21)
Has he even adjusted the suspension to see if it helps at all or is he just using the stock settings? There can be a huge difference between the ends of the spectrum on the suspension.
Old Aug 28, 2006 | 11:31 AM
VRD^don's Avatar
Default Re: lowering your bikes?? (Etylorcen)
everything still in stock form...he's already doing the one cheek sneak..this is just for daily driving..no HARD driving..maybe alittle here and there..i think he'll be good with the one cheek sneak thing....lowering the bike seems kinda hard..lol..thanks for everything guys!!!!
Nameless Warrior
Honda Motorcycles
38
Sep 18, 2007 11:02 PM
HS2G
Honda Motorcycles
35
Aug 1, 2005 06:19 AM
slowassR
Honda Motorcycles
19
Nov 17, 2004 04:56 PM
mellenium
Honda Motorcycles
15
Jan 25, 2004 05:59 AM
Vtecb16A
Honda Motorcycles
Apr 9, 2003 08:15 PM
